Design Span (L): 13.75 ft.
Clear Span: 13.50 ft.
Total Span: 14.00 ft.
Live Load: 80 plf
Dead Load: 10 plf
Selfweight: 120.2 lbs
Dist. Selfweight: 8.74 plf
Total Weight: 122.4 lbs
Beam Design 2025A26
1/23/2025 1
Beam Design 2025A26
1/23/2025 2
= 38.58 lbs/ft3
Volumetotal = N[A x (L + lb)] = 3 x [10.88 x (165.00 + 3)] x (12 in./ft.)3 = 3.17 ft3
Volumespan = N[A x L] = 3 x [10.88 x 165.00] x (12 in./ft.)3 = 3.12 ft3
Total Weight (WT) = ρw x Volumetotal = 38.58 x 3.17 = 122.4 lbs
Self Weight (WS) = ρw x Volumespan = 38.58 x 3.12 = 120.2 lbs
Distributed Self Weight (ws) = = 8.74 plf
80 plf
10 plf
ws = 8.74 plf
13.75 ft.
13.50 ft.
691.19 lbs
691.19 lbs
Beam Design 2025A26
1/23/2025 3
Fbx' = (925)(1.15)(1)(1)(1)(1)(1)(1.15) = 1223.3 psi
fb = = 710.3 psi
 fb = 710.3 psi < Fbx' = 1223.3 psi  (CSI = 0.58)   ➜  OK
Beam Design 2025A26
1/23/2025 4
fv* = = 28.47 psi
 fv* = 28.47 psi < Fvx' = 195.21 psi  (CSI = 0.15)   ➜  OK
fv = = 31.21 psi
 fv = 31.21 psi < Fvx' = 195.21 psi  (CSI = 0.16)   ➜  OK
Beam Design 2025A26
1/23/2025 5
ΔLL = = 0.36 in.
(L/d)LL = 165.00 / 0.36 = 462
 ΔLL = 0.36 in = L/462 < L/360   ➜  OK
ΔTL = = 0.44 in.
(L/d)TL = 165.00 / 0.44 = 374
 ΔTL = 0.44 in = L/374 < L/240   ➜  OK
fc⊥ = = 51.2 psi
 fc⊥ = 51.2 psi < Fc⊥x' = 378.55 psi  (CSI = 0.14)   ➜  OK
Beam Design 2025A26
1/23/2025 6
