Beam Design - Roof Beam@ living rm
Size: 5.5 x 10.5
Design Span (L): 12.75 ft.
Clear Span: 12.50 ft.
Total Span: 13.00 ft.
Live Load: 383 plf
Dead Load: 302 plf
Selfweight: 172.6 lbs
Dist. Selfweight: 13.54 plf
Total Weight: 176.0 lbs
Beam Design Keith Eilers 1195 Beach Ave, Lummi Is WA 98262 310
1/16/2025 1
d = 10.500 in.
A = 5.500 x 10.500 = 57.75 in.2
Sx = (5.500)(10.500)2/6 = 101.06 in.3
Sy = (5.500)2(10.500)/6 = 52.94 in.3
Ix = (5.500)(10.500)3/12 = 530.58 in.4
Iy = (5.500)3(10.500)/12 = 145.58 in.4
1/16/2025 2
Volumetotal = N[A x (L + lb)] = 1 x [57.75 x (153.00 + 3)] x (12 in./ft.)3 = 5.21 ft3
Volumespan = N[A x L] = 1 x [57.75 x 153.00] x (12 in./ft.)3 = 5.11 ft3
Total Weight (WT) = ρw x Volumetotal = 33.76 x 5.21 = 176.0 lbs
Self Weight (WS) = ρw x Volumespan = 33.76 x 5.11 = 172.6 lbs
383 plf
302 plf
  ws = 13.54 plf
12.75 ft.
12.50 ft.
13.00 ft.
4540.51 lbs
4540.51 lbs
1/16/2025 3
fb = = 1685.4 psi
 fb = 1685.4 psi < Fbx' = 2760.0 psi  (CSI = 0.61)   ➜  OK
1/16/2025 4
fv* = = 99.79 psi
 fv* = 99.79 psi < Fvx' = 304.75 psi  (CSI = 0.33)   ➜  OK
fv = = 115.67 psi
 fv = 115.67 psi < Fvx' = 304.75 psi  (CSI = 0.38)   ➜  OK
1/16/2025 5
ΔLL = = 0.24 in.
(L/d)LL = 153.00 / 0.24 = 642
 ΔLL = 0.24 in = L/642 < L/360   ➜  OK
ΔTL = = 0.43 in.
(L/d)TL = 153.00 / 0.43 = 352
 ΔTL = 0.43 in = L/352 < L/240   ➜  OK
fc⊥ = = 275.2 psi
 fc⊥ = 275.2 psi < Fc⊥x' = 650.00 psi  (CSI = 0.42)   ➜  OK
1/16/2025 6
