Beam Design - gm
Size: 3.5 x 24
Design Span (L): 39.75 ft.
Clear Span: 39.50 ft.
Total Span: 40.00 ft.
Live Load: 40 plf
Dead Load: 10 plf
Selfweight: 782.8 lbs
Dist. Selfweight: 19.69 plf
Total Weight: 787.8 lbs
CV Volume Factor 0.909b - - - - -
Beam Design Debra Duffy 9424 NE DERBY WAY 1
1/14/2025 1
d = 24.000 in.
A = 3.500 x 24.000 = 84.00 in.2
Sx = (3.500)(24.000)2/6 = 336.00 in.3
Sy = (3.500)2(24.000)/6 = 49.00 in.3
Ix = (3.500)(24.000)3/12 = 4032.00 in.4
Iy = (3.500)3(24.000)/12 = 85.75 in.4
1/14/2025 2
Volumetotal = N[A x (L + lb)] = 1 x [84.00 x (477.00 + 3)] x (12 in./ft.)3 = 23.33 ft3
Volumespan = N[A x L] = 1 x [84.00 x 477.00] x (12 in./ft.)3 = 23.19 ft3
Total Weight (WT) = ρw x Volumetotal = 33.76 x 23.33 = 787.8 lbs
Self Weight (WS) = ρw x Volumespan = 33.76 x 23.19 = 782.8 lbs
Distributed Self Weight (ws) = = 19.69 plf
40 plf
10 plf
  ws = 19.69 plf
39.75 ft.
39.50 ft.
40.00 ft.
1393.88 lbs
1393.88 lbs
1/14/2025 3
CV = = 0.909
CV = 0.909 < CL = 1
Fbx' = (2400)(1.15)(1)(1)(0.909) = 2509.9 psi
fb = = 491.6 psi
 fb = 491.6 psi < Fbx' = 2509.9 psi  (CSI = 0.20)   ➜  OK
1/14/2025 4
fv* = = 22.25 psi
 fv* = 22.25 psi < Fvx' = 304.75 psi  (CSI = 0.07)   ➜  OK
fv = = 24.74 psi
 fv = 24.74 psi < Fvx' = 304.75 psi  (CSI = 0.08)   ➜  OK
1/14/2025 5
ΔLL = = 0.31 in.
(L/d)LL = 477.00 / 0.31 = 1541
 ΔLL = 0.31 in = L/1541 < L/360   ➜  OK
ΔTL = = 0.54 in.
(L/d)TL = 477.00 / 0.54 = 884
 ΔTL = 0.54 in = L/884 < L/240   ➜  OK
fc⊥ = = 132.8 psi
 fc⊥ = 132.8 psi < Fc⊥x' = 650.00 psi  (CSI = 0.20)   ➜  OK
1/14/2025 6
