Beam Design - Center Beam
Design Span (L): 9.75 ft.
Clear Span: 9.50 ft.
Total Span: 10.00 ft.
Live Load: 40 plf
Dead Load: 10 plf
Selfweight: 75.6 lbs
Dist. Selfweight: 7.75 plf
Total Weight: 77.5 lbs
Beam Design 3419 Smallwood Rd. Warsaw
1/10/2025 1
1/10/2025 2
Volumetotal = N[A x (L + lb)] = 3 x [10.88 x (117.00 + 3)] x (12 in./ft.)3 = 2.27 ft3
Volumespan = N[A x L] = 3 x [10.88 x 117.00] x (12 in./ft.)3 = 2.21 ft3
Total Weight (WT) = ρw x Volumetotal = 34.20 x 2.27 = 77.5 lbs
Self Weight (WS) = ρw x Volumespan = 34.20 x 2.21 = 75.6 lbs
Distributed Self Weight (ws) = = 7.75 plf
40 plf
10 plf
ws = 7.75 plf
9.75 ft.
9.50 ft.
10.00 ft.
288.75 lbs
288.75 lbs
1/10/2025 3
Fbx' = (900)(1.00)(1)(1)(1)(1.2)(1)(1) = 1080.0 psi
fb = = 208.9 psi
 fb = 208.9 psi < Fbx' = 1080.0 psi  (CSI = 0.19)   ➜  OK
1/10/2025 4
fv* = = 11.34 psi
 fv* = 11.34 psi < Fvx' = 180.00 psi  (CSI = 0.06)   ➜  OK
fv = = 12.94 psi
 fv = 12.94 psi < Fvx' = 180.00 psi  (CSI = 0.07)   ➜  OK
1/10/2025 5
ΔLL = = 0.04 in.
(L/d)LL = 117.00 / 0.04 = 3289
 ΔLL = 0.04 in = L/3289 < L/360   ➜  OK
ΔTL = = 0.05 in.
(L/d)TL = 117.00 / 0.05 = 2278
 ΔTL = 0.05 in = L/2278 < L/240   ➜  OK
fc⊥ = = 21.4 psi
 fc⊥ = 21.4 psi < Fc⊥x' = 625.00 psi  (CSI = 0.03)   ➜  OK
1/10/2025 6
