Grade: SP DSS
Design Span (L): 19.75 ft.
Clear Span: 19.50 ft.
Total Span: 20.00 ft.
Live Load: 1800 lbs
Dead Load: 500 lbs
Selfweight: 172.8 lbs
Dist. Selfweight: 8.75 plf
Total Weight: 175.0 lbs
Lateral Support: 10' o/c
CL Beam Stability Factor 0.935 - - - - -
Beam Design 2025A101
4/22/2025 1
4/22/2025 2
Volumetotal = N[A x (L + lb)] = 2 x [16.88 x (237.00 + 3)] x (12 in./ft.)3 = 4.69 ft3
Volumespan = N[A x L] = 2 x [16.88 x 237.00] x (12 in./ft.)3 = 4.63 ft3
Total Weight (WT) = ρw x Volumetotal = 37.33 x 4.69 = 175.0 lbs
Self Weight (WS) = ρw x Volumespan = 37.33 x 4.63 = 172.8 lbs
1800 lbs
500 lbs
ws = 8.75 plf
19.75 ft.
19.50 ft.
1237.49 lbs
1237.49 lbs
4/22/2025 3
lu = Unbraced Length = 10 ft.
lu/d = = 10.67
le = 1.63lu + 3d = 1.63(120.0) + 3(11.25) = 229.35 in. = 19.11 ft.  (NDS Table 3.3.3)
Rb = = 16.93
 Rb = 16.93 < 50   ➜  OK
4/22/2025 4
FbE = = 2888.16 psi
Fbx* = Fbx(CD)(CM)(Ct)(CF)(Ci)(Cr) = (1800)(1.00)(1)(1)(1)(1)(1) = 1800.00 psi
CL =   = 0.935
Fbx' = (1800)(1.00)(1)(1)(0.935)(1)(1)(1) = 1682.6 psi
fb = = 2234.4 psi
 fb = 2234.4 psi > Fbx' = 1682.6 psi  (CSI = 1.33)   ➜  NG
fv* = = 54.59 psi
 fv* = 54.59 psi < Fvx' = 175.00 psi  (CSI = 0.31)   ➜  OK
fv = = 54.95 psi
 fv = 54.95 psi < Fvx' = 175.00 psi  (CSI = 0.31)   ➜  OK
4/22/2025 5
ΔLL =   =   = 0.74 in.
(L/d)LL = 237.00 / 0.74 = 321
 ΔLL = 0.74 in = L/321 > L/360   ➜  NG
ΔTL =   =   = 0.99 in.
(L/d)TL = 237.00 / 0.99 = 240
 ΔTL = 0.99 in = L/240 < L/240   ➜  OK
fc⊥ = = 137.5 psi
 fc⊥ = 137.5 psi < Fc⊥x' = 660.00 psi  (CSI = 0.21)   ➜  OK
4/22/2025 6
