Selfweight: 116.2 lbs
Dist. Selfweight: 9.89 plf
Total Weight: 118.6 lbs
Defl. Limits: 480|360
Beam Design 2025A10
1/10/2025 1
Beam Design 2025A10
1/10/2025 2
Volumetotal = N[A x (L + lb)] = 3 x [13.88 x (141.00 + 3)] x (12 in./ft.)3 = 3.47 ft3
Volumespan = N[A x L] = 3 x [13.88 x 141.00] x (12 in./ft.)3 = 3.40 ft3
Total Weight (WT) = ρw x Volumetotal = 34.20 x 3.47 = 118.6 lbs
Self Weight (WS) = ρw x Volumespan = 34.20 x 3.40 = 116.2 lbs
ws = 9.89 plf
1109.32 lbs
1109.32 lbs
Beam Design 2025A10
1/10/2025 3
fb = = 596.7 psi
 fb = 596.7 psi < Fbx' = 990.0 psi  (CSI = 0.60)   ➜  OK
Beam Design 2025A10
1/10/2025 4
fv* = = 34.01 psi
 fv* = 34.01 psi < Fvx' = 180.00 psi  (CSI = 0.19)   ➜  OK
fv = = 39.14 psi
 fv = 39.14 psi < Fvx' = 180.00 psi  (CSI = 0.22)   ➜  OK
LL Allowable: L/480
TL Allowable: L/360
Beam Design 2025A10
1/10/2025 5
ΔLL = = 0.09 in.
(L/d)LL = 141.00 / 0.09 = 1561
 ΔLL = 0.09 in = L/1561 < L/480   ➜  OK
ΔTL = = 0.17 in.
(L/d)TL = 141.00 / 0.17 = 844
 ΔTL = 0.17 in = L/844 < L/360   ➜  OK
fc⊥ = = 82.2 psi
 fc⊥ = 82.2 psi < Fc⊥x' = 625.00 psi  (CSI = 0.13)   ➜  OK
Beam Design 2025A10
1/10/2025 6
