Beam Design - AG Beam Ext 1
Grade: 24F-V8 1.8E DF/DF
Size: 5.5 x 12
Design Span (L): 17.71 ft.
Clear Span: 17.42 ft.
Total Span: 18.00 ft.
Bearing (lb): 3.5 in.
Live Load: 360 plf
Dead Load: 60 plf
Selfweight: 274.0 lbs
Dist. Selfweight: 15.47 plf
Total Weight: 278.5 lbs
Beam Design J.T. Heater 14618 Tyler Foote Road Nevada City, CA 2401
3/7/2024 1
3/7/2024 2
Volumetotal = N[A x (L + lb)] = 1 x [66.00 x (212.50 + 3.5)] x (12 in./ft.)3 = 8.25 ft3
Volumespan = N[A x L] = 1 x [66.00 x 212.50] x (12 in./ft.)3 = 8.12 ft3
Total Weight (WT) = ρw x Volumetotal = 33.76 x 8.25 = 278.5 lbs
Self Weight (WS) = ρw x Volumespan = 33.76 x 8.12 = 274.0 lbs
360 plf
60 plf
  ws = 15.47 plf
17.71 ft.
17.42 ft.
18.00 ft.
3919.19 lbs
3919.19 lbs
3/7/2024 3
lu/d = = 2.00
Rb = = 4.43
 Rb = 4.43 < 50   ➜  OK
3/7/2024 4
FbE = = 52007.48 psi
CL =   = 0.997
CL = 0.997 < CV = 1.0
Fbx' = (2400)(1.15)(1)(1)(0.997) = 2752.3 psi
fb = = 1551.7 psi
 fb = 1551.7 psi < Fbx' = 2752.3 psi  (CSI = 0.56)   ➜  OK
fv* = = 77.73 psi
3/7/2024 5
 fv* = 77.73 psi < Fvx' = 304.75 psi  (CSI = 0.26)   ➜  OK
fv = = 87.63 psi
 fv = 87.63 psi < Fvx' = 304.75 psi  (CSI = 0.29)   ➜  OK
ΔLL = = 0.56 in.
(L/d)LL = 212.50 / 0.56 = 380
 ΔLL = 0.56 in = L/380 < L/360   ➜  OK
ΔTL = = 0.68 in.
(L/d)TL = 212.50 / 0.68 = 314
 ΔTL = 0.68 in = L/314 < L/240   ➜  OK
3/7/2024 6
Ab = b x lb = 5.5 x 3.5 = 19.25 in2
fc⊥ = = 203.6 psi
 fc⊥ = 203.6 psi < Fc⊥x' = 650.00 psi  (CSI = 0.31)   ➜  OK
3/7/2024 7
