Grade: DF SS
Size: 4 x 8
Design Span (L): 13.25 ft.
Clear Span: 13.00 ft.
Total Span: 13.50 ft.
Live Load: 80 plf
Dead Load: 80 plf
Selfweight: 79.9 lbs
Dist. Selfweight: 6.03 plf
Total Weight: 81.4 lbs
Beam Design 2024A90
3/6/2024 1
Beam Design 2024A90
3/6/2024 2
Volumetotal = N[A x (L + lb)] = 1 x [25.38 x (159.00 + 3)] x (12 in./ft.)3 = 2.38 ft3
Volumespan = N[A x L] = 1 x [25.38 x 159.00] x (12 in./ft.)3 = 2.33 ft3
Total Weight (WT) = ρw x Volumetotal = 34.20 x 2.38 = 81.4 lbs
Self Weight (WS) = ρw x Volumespan = 34.20 x 2.33 = 79.9 lbs
80 plf
80 plf
ws = 6.03 plf
13.25 ft.
13.00 ft.
13.50 ft.
1120.68 lbs
1120.68 lbs
Beam Design 2024A90
3/6/2024 3
Fbx' = (1500)(1.00)(1)(1)(1)(1.3)(1)(1) = 1950.0 psi
fb = = 1426.0 psi
 fb = 1426.0 psi < Fbx' = 1950.0 psi  (CSI = 0.73)   ➜  OK
Beam Design 2024A90
3/6/2024 4
fv* = = 59.09 psi
 fv* = 59.09 psi < Fvx' = 180.00 psi  (CSI = 0.33)   ➜  OK
fv = = 65.02 psi
 fv = 65.02 psi < Fvx' = 180.00 psi  (CSI = 0.36)   ➜  OK
Beam Design 2024A90
3/6/2024 5
ΔLL = = 0.26 in.
(L/d)LL = 159.00 / 0.26 = 605
 ΔLL = 0.26 in = L/605 < L/360   ➜  OK
ΔTL = = 0.55 in.
(L/d)TL = 159.00 / 0.55 = 292
 ΔTL = 0.55 in = L/292 < L/240   ➜  OK
fc⊥ = = 106.7 psi
 fc⊥ = 106.7 psi < Fc⊥x' = 625.00 psi  (CSI = 0.17)   ➜  OK
Beam Design 2024A90
3/6/2024 6
