Grade: DF SS
Design Span (L): 14.50 ft.
Clear Span: 14.00 ft.
Total Span: 15.00 ft.
Live Load: 45 plf
Selfweight: 47.8 lbs
Dist. Selfweight: 3.30 plf
Total Weight: 49.4 lbs
Beam Design 2024A83
3/5/2024 1
Beam Design 2024A83
3/5/2024 2
Volumetotal = N[A x (L + lb)] = 1 x [13.88 x (174.00 + 6)] x (12 in./ft.)3 = 1.45 ft3
Volumespan = N[A x L] = 1 x [13.88 x 174.00] x (12 in./ft.)3 = 1.40 ft3
Total Weight (WT) = ρw x Volumetotal = 34.20 x 1.45 = 49.4 lbs
Self Weight (WS) = ρw x Volumespan = 34.20 x 1.40 = 47.8 lbs
45 plf
ws = 3.30 plf
14.50 ft.
15.00 ft.
924.72 lbs
924.72 lbs
Beam Design 2024A83
3/5/2024 3
Fbx' = (1500)(1.15)(1)(1)(1)(1.1)(1)(1) = 1897.5 psi
fb = = 1817.8 psi
 fb = 1817.8 psi < Fbx' = 1897.5 psi  (CSI = 0.96)   ➜  OK
Beam Design 2024A83
3/5/2024 4
fv* = = 86.36 psi
 fv* = 86.36 psi < Fvx' = 207.00 psi  (CSI = 0.42)   ➜  OK
fv = = 96.64 psi
 fv = 96.64 psi < Fvx' = 207.00 psi  (CSI = 0.47)   ➜  OK
Beam Design 2024A83
3/5/2024 5
ΔLL = = 0.24 in.
(L/d)LL = 174.00 / 0.24 = 731
 ΔLL = 0.24 in = L/731 < L/360   ➜  OK
ΔTL = = 0.65 in.
(L/d)TL = 174.00 / 0.65 = 267
 ΔTL = 0.65 in = L/267 < L/240   ➜  OK
fc⊥ = = 102.7 psi
 fc⊥ = 102.7 psi < Fc⊥x' = 625.00 psi  (CSI = 0.16)   ➜  OK
Beam Design 2024A83
3/5/2024 6
