Beam Design - Truss Bottom Chord as Beam
Size: 2 x 4
Design Span (L): 9.75 ft.
Clear Span: 9.50 ft.
Total Span: 10.00 ft.
Live Load: 0 plf
Dead Load: 4 plf
Selfweight: 12.2 lbs
Dist. Selfweight: 1.25 plf
Total Weight: 12.5 lbs
Notes: Truss Bottom Chord as Beam
Remove Load Factors
Beam Design Gregory Smith Sun City West, AZ 2024001
3/4/2024 1
d = 3.500 in.
A = 1.500 x 3.500 = 5.25 in.2
3/4/2024 2
Volumetotal = N[A x (L + lb)] = 1 x [5.25 x (117.00 + 3)] x (12 in./ft.)3 = 0.36 ft3
Volumespan = N[A x L] = 1 x [5.25 x 117.00] x (12 in./ft.)3 = 0.36 ft3
Total Weight (WT) = ρw x Volumetotal = 34.20 x 0.36 = 12.5 lbs
Self Weight (WS) = ρw x Volumespan = 34.20 x 0.36 = 12.2 lbs
Distributed Self Weight (ws) = = 1.25 plf
0 plf
4 plf
ws = 1.25 plf
9.75 ft.
9.50 ft.
10.00 ft.
26.24 lbs
26.24 lbs
3/4/2024 3
Fbx' = (900)(0.9)(1)(1)(1)(1.5)(1)(1) = 1215.0 psi
fb = = 244.3 psi
 fb = 244.3 psi < Fbx' = 1215.0 psi  (CSI = 0.20)   ➜  OK
3/4/2024 4
fv* = = 6.87 psi
 fv* = 6.87 psi < Fvx' = 162.00 psi  (CSI = 0.04)   ➜  OK
fv = = 7.31 psi
 fv = 7.31 psi < Fvx' = 162.00 psi  (CSI = 0.05)   ➜  OK
3/4/2024 5
ΔLL = = 0.00 in.
(L/d)LL = 117.00 / 0.00 = ∞
ΔTL = = 0.12 in.
(L/d)TL = 117.00 / 0.12 = 940
 ΔTL = 0.12 in = L/940 < L/120   ➜  OK
fc⊥ = = 5.8 psi
 fc⊥ = 5.8 psi < Fc⊥x' = 625.00 psi  (CSI = 0.01)   ➜  OK
3/4/2024 6
