Beam Design - Garage Header as Beam
Design Span (L): 8.05 ft.
Clear Span: 7.80 ft.
Total Span: 8.30 ft.
Live Load: 58 plf
Dead Load: 11 plf
Selfweight: 26.5 lbs
Dist. Selfweight: 3.30 plf
Total Weight: 27.4 lbs
Beam Design Gregory Smith 14422 W Via Tercero Dr. 2024001
3/4/2024 1
3/4/2024 2
Volumetotal = N[A x (L + lb)] = 1 x [13.88 x (96.60 + 3)] x (12 in./ft.)3 = 0.80 ft3
Volumespan = N[A x L] = 1 x [13.88 x 96.60] x (12 in./ft.)3 = 0.78 ft3
Total Weight (WT) = ρw x Volumetotal = 34.20 x 0.80 = 27.4 lbs
Self Weight (WS) = ρw x Volumespan = 34.20 x 0.78 = 26.5 lbs
58 plf
11 plf
ws = 3.30 plf
8.05 ft.
7.80 ft.
8.30 ft.
300.03 lbs
300.03 lbs
3/4/2024 3
fb = = 328.5 psi
 fb = 328.5 psi < Fbx' = 1138.5 psi  (CSI = 0.29)   ➜  OK
3/4/2024 4
fv* = = 25.43 psi
 fv* = 25.43 psi < Fvx' = 207.00 psi  (CSI = 0.12)   ➜  OK
fv = = 31.46 psi
 fv = 31.46 psi < Fvx' = 207.00 psi  (CSI = 0.15)   ➜  OK
3/4/2024 5
ΔLL = = 0.03 in.
(L/d)LL = 96.60 / 0.03 = 2790
 ΔLL = 0.03 in = L/2790 < L/180   ➜  OK
ΔTL = = 0.04 in.
(L/d)TL = 96.60 / 0.04 = 2238
 ΔTL = 0.04 in = L/2238 < L/120   ➜  OK
fc⊥ = = 66.7 psi
 fc⊥ = 66.7 psi < Fc⊥x' = 625.00 psi  (CSI = 0.11)   ➜  OK
3/4/2024 6
