Beam Design - Sample Beam
Design Span (L): 8.05 ft.
Clear Span: 7.80 ft.
Total Span: 8.30 ft.
Live Load: 200 plf
Selfweight: 26.5 lbs
Dist. Selfweight: 3.30 plf
Total Weight: 27.4 lbs
Beam Design GSC 2024A73
3/4/2024 1
3/4/2024 2
Volumetotal = N[A x (L + lb)] = 1 x [13.88 x (96.60 + 3)] x (12 in./ft.)3 = 0.80 ft3
Volumespan = N[A x L] = 1 x [13.88 x 96.60] x (12 in./ft.)3 = 0.78 ft3
Total Weight (WT) = ρw x Volumetotal = 34.20 x 0.80 = 27.4 lbs
Self Weight (WS) = ρw x Volumespan = 34.20 x 0.78 = 26.5 lbs
200 plf
ws = 3.30 plf
8.05 ft.
7.80 ft.
8.30 ft.
1154.93 lbs
1154.93 lbs
3/4/2024 3
fb = = 1264.6 psi
 fb = 1264.6 psi > Fbx' = 990.0 psi  (CSI = 1.28)   ➜  NG
3/4/2024 4
fv* = = 97.90 psi
 fv* = 97.90 psi < Fvx' = 180.00 psi  (CSI = 0.54)   ➜  OK
fv = = 121.10 psi
 fv = 121.10 psi < Fvx' = 180.00 psi  (CSI = 0.67)   ➜  OK
3/4/2024 5
ΔLL = = 0.12 in.
(L/d)LL = 96.60 / 0.12 = 809
 ΔLL = 0.12 in = L/809 < L/360   ➜  OK
ΔTL = = 0.17 in.
(L/d)TL = 96.60 / 0.17 = 582
 ΔTL = 0.17 in = L/582 < L/240   ➜  OK
fc⊥ = = 256.7 psi
 fc⊥ = 256.7 psi < Fc⊥x' = 625.00 psi  (CSI = 0.41)   ➜  OK
3/4/2024 6
