Grade: 24F-V3 1.8E SP/SP
Size: 3.5 x 11
Design Span (L): 16.00 ft.
Clear Span: 15.75 ft.
Total Span: 16.25 ft.
Live Load: 325 plf
Dead Load: 132 plf
Selfweight: 157.8 lbs
Dist. Selfweight: 9.86 plf
Total Weight: 160.3 lbs
Beam Design 2024A71
2/29/2024 1
d = 11.000 in.
A = 3.500 x 11.000 = 38.50 in.2
Sx = (3.500)(11.000)2/6 = 70.58 in.3
Sy = (3.500)2(11.000)/6 = 22.46 in.3
Ix = (3.500)(11.000)3/12 = 388.21 in.4
Iy = (3.500)3(11.000)/12 = 39.30 in.4
Beam Design 2024A71
2/29/2024 2
= 36.89 lbs/ft3
Volumetotal = N[A x (L + lb)] = 1 x [38.50 x (192.00 + 3)] x (12 in./ft.)3 = 4.34 ft3
Volumespan = N[A x L] = 1 x [38.50 x 192.00] x (12 in./ft.)3 = 4.28 ft3
Total Weight (WT) = ρw x Volumetotal = 36.89 x 4.34 = 160.3 lbs
Self Weight (WS) = ρw x Volumespan = 36.89 x 4.28 = 157.8 lbs
Distributed Self Weight (ws) = = 9.86 plf
325 plf
132 plf
  ws = 9.86 plf
15.75 ft.
16.25 ft.
3793.26 lbs
3793.26 lbs
Beam Design 2024A71
2/29/2024 3
fb = = 2539.9 psi
 fb = 2539.9 psi < Fbx' = 2760.0 psi  (CSI = 0.92)   ➜  OK
Beam Design 2024A71
2/29/2024 4
fv* = = 128.84 psi
 fv* = 128.84 psi < Fvx' = 345.00 psi  (CSI = 0.37)   ➜  OK
fv = = 145.52 psi
 fv = 145.52 psi < Fvx' = 345.00 psi  (CSI = 0.42)   ➜  OK
Beam Design 2024A71
2/29/2024 5
ΔLL = = 0.69 in.
(L/d)LL = 192.00 / 0.69 = 280
 ΔLL = 0.69 in = L/280 < L/180   ➜  OK
ΔTL = = 0.99 in.
(L/d)TL = 192.00 / 0.99 = 195
 ΔTL = 0.99 in = L/195 < L/120   ➜  OK
fc⊥ = = 361.3 psi
 fc⊥ = 361.3 psi < Fc⊥x' = 740.00 psi  (CSI = 0.49)   ➜  OK
Beam Design 2024A71
2/29/2024 6
