Grade: 24F-V3 1.8E SP/SP
Size: 3.5 x 11
Design Span (L): 16.00 ft.
Clear Span: 15.75 ft.
Total Span: 16.25 ft.
Selfweight: 157.8 lbs
Dist. Selfweight: 9.86 plf
Total Weight: 160.3 lbs
Load Duration: 1.33
Beam Design 2024A70
2/28/2024 1
d = 11.000 in.
A = 3.500 x 11.000 = 38.50 in.2
Sx = (3.500)(11.000)2/6 = 70.58 in.3
Sy = (3.500)2(11.000)/6 = 22.46 in.3
Ix = (3.500)(11.000)3/12 = 388.21 in.4
Iy = (3.500)3(11.000)/12 = 39.30 in.4
Beam Design 2024A70
2/28/2024 2
= 36.89 lbs/ft3
Volumetotal = N[A x (L + lb)] = 1 x [38.50 x (192.00 + 3)] x (12 in./ft.)3 = 4.34 ft3
Volumespan = N[A x L] = 1 x [38.50 x 192.00] x (12 in./ft.)3 = 4.28 ft3
Total Weight (WT) = ρw x Volumetotal = 36.89 x 4.34 = 160.3 lbs
Self Weight (WS) = ρw x Volumespan = 36.89 x 4.28 = 157.8 lbs
Distributed Self Weight (ws) = = 9.86 plf
  ws = 9.86 plf
15.75 ft.
16.25 ft.
1502.01 lbs
1502.01 lbs
Beam Design 2024A70
2/28/2024 3
Fbx' = (2400)(1.33)(1)(1)(1.0) = 3192.0 psi
fb = = 1005.7 psi
 fb = 1005.7 psi < Fbx' = 3192.0 psi  (CSI = 0.32)   ➜  OK
Beam Design 2024A70
2/28/2024 4
Fvx' = (300)(1.33)(1)(1) = 399.00 psi
fv* = = 51.02 psi
 fv* = 51.02 psi < Fvx' = 399.00 psi  (CSI = 0.13)   ➜  OK
fv = = 57.62 psi
 fv = 57.62 psi < Fvx' = 399.00 psi  (CSI = 0.14)   ➜  OK
Beam Design 2024A70
2/28/2024 5
ΔLL = = 0.21 in.
(L/d)LL = 192.00 / 0.21 = 910
 ΔLL = 0.21 in = L/910 < L/360   ➜  OK
ΔTL = = 0.39 in.
(L/d)TL = 192.00 / 0.39 = 492
 ΔTL = 0.39 in = L/492 < L/240   ➜  OK
fc⊥ = = 143.0 psi
 fc⊥ = 143.0 psi < Fc⊥x' = 740.00 psi  (CSI = 0.19)   ➜  OK
Beam Design 2024A70
2/28/2024 6
