Grade: SP SS
Design Span (L): 15.92 ft.
Clear Span: 15.58 ft.
Total Span: 16.25 ft.
Bearing (lb): 4 in.
Live Load: 325 plf
Dead Load: 132 plf
Selfweight: 208.9 lbs
Dist. Selfweight: 13.12 plf
Total Weight: 213.3 lbs
Load Duration: 1.33
Beam Design 2024A68
2/27/2024 1
SP SS 1600 1100 175 565 1650 1800000 660000 0.55
Beam Design 2024A68
2/27/2024 2
Volumetotal = N[A x (L + lb)] = 3 x [16.88 x (191.00 + 4)] x (12 in./ft.)3 = 5.71 ft3
Volumespan = N[A x L] = 3 x [16.88 x 191.00] x (12 in./ft.)3 = 5.60 ft3
Total Weight (WT) = ρw x Volumetotal = 37.33 x 5.71 = 213.3 lbs
Self Weight (WS) = ρw x Volumespan = 37.33 x 5.60 = 208.9 lbs
325 plf
132 plf
ws = 13.12 plf
15.92 ft.
15.58 ft.
16.25 ft.
3819.83 lbs
3819.83 lbs
Beam Design 2024A68
2/27/2024 3
Fbx' = (1600)(1.33)(1)(1)(1)(1)(1)(1) = 2128.0 psi
fb = = 1882.2 psi
 fb = 1882.2 psi < Fbx' = 2128.0 psi  (CSI = 0.88)   ➜  OK
Beam Design 2024A68
2/27/2024 4
Fvx' = (175)(1.33)(1)(1)(1) = 232.75 psi
fv* = = 97.80 psi
 fv* = 97.80 psi < Fvx' = 232.75 psi  (CSI = 0.42)   ➜  OK
fv = = 110.86 psi
 fv = 110.86 psi < Fvx' = 232.75 psi  (CSI = 0.48)   ➜  OK
Beam Design 2024A68
2/27/2024 5
ΔLL = = 0.49 in.
(L/d)LL = 191.00 / 0.49 = 391
 ΔLL = 0.49 in = L/391 < L/360   ➜  OK
ΔTL = = 0.71 in.
(L/d)TL = 191.00 / 0.71 = 270
 ΔTL = 0.71 in = L/270 < L/240   ➜  OK
fc⊥ = = 212.2 psi
 fc⊥ = 212.2 psi < Fc⊥x' = 565.00 psi  (CSI = 0.38)   ➜  OK
Beam Design 2024A68
2/27/2024 6
