Size: 4 x 8
Design Span (L): 15.75 ft.
Clear Span: 15.50 ft.
Total Span: 16.00 ft.
Live Load: 80 plf
Dead Load: 80 plf
Selfweight: 94.9 lbs
Dist. Selfweight: 6.03 plf
Total Weight: 96.4 lbs
Beam Design 2024A65
2/23/2024 1
Beam Design 2024A65
2/23/2024 2
Volumetotal = N[A x (L + lb)] = 1 x [25.38 x (189.00 + 3)] x (12 in./ft.)3 = 2.82 ft3
Volumespan = N[A x L] = 1 x [25.38 x 189.00] x (12 in./ft.)3 = 2.78 ft3
Total Weight (WT) = ρw x Volumetotal = 34.20 x 2.82 = 96.4 lbs
Self Weight (WS) = ρw x Volumespan = 34.20 x 2.78 = 94.9 lbs
80 plf
80 plf
ws = 6.03 plf
15.75 ft.
15.50 ft.
1328.22 lbs
1328.22 lbs
Beam Design 2024A65
2/23/2024 3
fb = = 2014.8 psi
 fb = 2014.8 psi > Fbx' = 1170.0 psi  (CSI = 1.72)   ➜  NG
Beam Design 2024A65
2/23/2024 4
fv* = = 71.36 psi
 fv* = 71.36 psi < Fvx' = 180.00 psi  (CSI = 0.40)   ➜  OK
fv = = 77.29 psi
 fv = 77.29 psi < Fvx' = 180.00 psi  (CSI = 0.43)   ➜  OK
Beam Design 2024A65
2/23/2024 5
ΔLL = = 0.62 in.
(L/d)LL = 189.00 / 0.62 = 303
 ΔLL = 0.62 in = L/303 > L/360   ➜  NG
ΔTL = = 1.29 in.
(L/d)TL = 189.00 / 1.29 = 146
 ΔTL = 1.29 in = L/146 > L/240   ➜  NG
fc⊥ = = 126.5 psi
 fc⊥ = 126.5 psi < Fc⊥x' = 625.00 psi  (CSI = 0.20)   ➜  OK
Beam Design 2024A65
2/23/2024 6
