Grade: SPF SS
Design Span (L): 9.25 ft.
Clear Span: 9.00 ft.
Total Span: 9.50 ft.
Live Load: 190 plf
Dead Load: 95 plf
Selfweight: 40.7 lbs
Dist. Selfweight: 4.39 plf
Total Weight: 41.8 lbs
CL Beam Stability Factor 0.966 - - - - -
Beam Design 2024A61
2/22/2024 1
Beam Design 2024A61
2/22/2024 2
Volumetotal = N[A x (L + lb)] = 2 x [10.88 x (111.00 + 3)] x (12 in./ft.)3 = 1.43 ft3
Volumespan = N[A x L] = 2 x [10.88 x 111.00] x (12 in./ft.)3 = 1.40 ft3
Total Weight (WT) = ρw x Volumetotal = 29.10 x 1.43 = 41.8 lbs
Self Weight (WS) = ρw x Volumespan = 29.10 x 1.40 = 40.7 lbs
190 plf
95 plf
ws = 4.39 plf
9.25 ft.
9.00 ft.
9.50 ft.
1374.63 lbs
1374.63 lbs
Beam Design 2024A61
2/22/2024 3
lu = Unbraced Length = 9.250 ft.
lu/d = = 15.31
le = 1.63lu + 3d = 1.63(111.0) + 3(7.25) = 202.68 in. = 16.89 ft.  (NDS Table 3.3.3)
Rb = = 12.78
 Rb = 12.78 < 50   ➜  OK
Beam Design 2024A61
2/22/2024 4
FbE = = 4042.38 psi
Fbx* = Fbx(CD)(CM)(Ct)(CF)(Ci)(Cr) = (1250)(1.15)(1)(1)(1.2)(1)(1) = 1725.00 psi
CL =   = 0.966
Fbx' = (1250)(1.15)(1)(1)(0.966)(1.2)(1)(1) = 1666.5 psi
fb = = 1413.3 psi
 fb = 1413.3 psi < Fbx' = 1666.5 psi  (CSI = 0.85)   ➜  OK
fv* = = 80.25 psi
 fv* = 80.25 psi < Fvx' = 155.25 psi  (CSI = 0.52)   ➜  OK
fv = = 92.31 psi
 fv = 92.31 psi < Fvx' = 155.25 psi  (CSI = 0.59)   ➜  OK
Beam Design 2024A61
2/22/2024 5
ΔLL = = 0.22 in.
(L/d)LL = 111.00 / 0.22 = 507
 ΔLL = 0.22 in = L/507 < L/180   ➜  OK
ΔTL = = 0.33 in.
(L/d)TL = 111.00 / 0.33 = 333
 ΔTL = 0.33 in = L/333 < L/120   ➜  OK
fc⊥ = = 152.7 psi
 fc⊥ = 152.7 psi < Fc⊥x' = 425.00 psi  (CSI = 0.36)   ➜  OK
Beam Design 2024A61
2/22/2024 6
