Size: 2.5 x 6
Design Span (L): 19.25 ft.
Clear Span: 19.00 ft.
Total Span: 19.50 ft.
Selfweight: 71.1 lbs
Dist. Selfweight: 3.69 plf
Total Weight: 72.0 lbs
Beam Design 2024A57
2/19/2024 1
b = 2.500 in.
d = 6.000 in.
A = 2.500 x 6.000 = 15.00 in.2
Sx = (2.500)(6.000)2/6 = 15.00 in.3
Sy = (2.500)2(6.000)/6 = 6.25 in.3
Ix = (2.500)(6.000)3/12 = 45.00 in.4
Iy = (2.500)3(6.000)/12 = 7.81 in.4
Beam Design 2024A57
2/19/2024 2
Volumetotal = N[A x (L + lb)] = 1 x [15.00 x (231.00 + 3)] x (12 in./ft.)3 = 2.03 ft3
Volumespan = N[A x L] = 1 x [15.00 x 231.00] x (12 in./ft.)3 = 2.01 ft3
Total Weight (WT) = ρw x Volumetotal = 35.47 x 2.03 = 72.0 lbs
Self Weight (WS) = ρw x Volumespan = 35.47 x 2.01 = 71.1 lbs
Distributed Self Weight (ws) = = 3.69 plf
  ws = 3.69 plf
19.25 ft.
19.00 ft.
19.50 ft.
1742.27 lbs
1742.27 lbs
Beam Design 2024A57
2/19/2024 3
fb = = 6621.7 psi
 fb = 6621.7 psi > Fbx' = 2208.0 psi  (CSI = 3.00)   ➜  NG
Beam Design 2024A57
2/19/2024 4
fv* = = 163.06 psi
 fv* = 163.06 psi < Fvx' = 266.66 psi  (CSI = 0.61)   ➜  OK
fv = = 171.99 psi
 fv = 171.99 psi < Fvx' = 266.66 psi  (CSI = 0.65)   ➜  OK
Beam Design 2024A57
2/19/2024 5
ΔLL = = 4.58 in.
(L/d)LL = 231.00 / 4.58 = 50
 ΔLL = 4.58 in = L/50 > L/360   ➜  NG
ΔTL = = 8.18 in.
(L/d)TL = 231.00 / 8.18 = 28
 ΔTL = 8.18 in = L/28 > L/240   ➜  NG
fc⊥ = = 232.3 psi
 fc⊥ = 232.3 psi < Fc⊥x' = 344.50 psi  (CSI = 0.67)   ➜  OK
Beam Design 2024A57
2/19/2024 6
