Size: 12.25 x 60
Design Span (L): 104.25 ft.
Clear Span: 104.00 ft.
Total Span: 104.50 ft.
Live Load: 70 plf
Dead Load: 40 plf
Selfweight: 17964.6 lbs
Dist. Selfweight: 172.32 plf
Total Weight: 18007.7 lbs
CV Volume Factor 0.665b - - - - -
Beam Design 2024A56
2/19/2024 1
b = 12.250 in.
d = 60.000 in.
A = 12.250 x 60.000 = 735.00 in.2
Sx = (12.250)(60.000)2/6 = 7350.00 in.3
Sy = (12.250)2(60.000)/6 = 1500.63 in.3
Ix = (12.250)(60.000)3/12 = 220500.00 in.4
Iy = (12.250)3(60.000)/12 = 9191.33 in.4
Beam Design 2024A56
2/19/2024 2
Volumetotal = N[A x (L + lb)] = 1 x [735.00 x (1251.00 + 3)] x (12 in./ft.)3 = 533.39 ft3
Volumespan = N[A x L] = 1 x [735.00 x 1251.00] x (12 in./ft.)3 = 532.11 ft3
Total Weight (WT) = ρw x Volumetotal = 33.76 x 533.39 = 18007.7 lbs
Self Weight (WS) = ρw x Volumespan = 33.76 x 532.11 = 17964.6 lbs
Distributed Self Weight (ws) = = 172.32 plf
70 plf
40 plf
  ws = 172.32 plf
104.25 ft.
104.00 ft.
104.50 ft.
14751.36 lbs
14751.36 lbs
Beam Design 2024A56
2/19/2024 3
CV = = 0.665
CV = 0.665 < CL = 1
Fbx' = (2400)(1.15)(1)(1)(0.665) = 1834.8 psi
fb = = 626.2 psi
 fb = 626.2 psi < Fbx' = 1834.8 psi  (CSI = 0.34)   ➜  OK
Beam Design 2024A56
2/19/2024 4
fv* = = 27.15 psi
 fv* = 27.15 psi < Fvx' = 304.75 psi  (CSI = 0.09)   ➜  OK
fv = = 30.03 psi
 fv = 30.03 psi < Fvx' = 304.75 psi  (CSI = 0.10)   ➜  OK
Beam Design 2024A56
2/19/2024 5
ΔLL = = 0.47 in.
(L/d)LL = 1251.00 / 0.47 = 2669
 ΔLL = 0.47 in = L/2669 < L/360   ➜  OK
ΔTL = = 1.89 in.
(L/d)TL = 1251.00 / 1.89 = 662
 ΔTL = 1.89 in = L/662 < L/240   ➜  OK
Ab = b x lb = 12.25 x 3 = 36.75 in2
fc⊥ = = 401.4 psi
 fc⊥ = 401.4 psi < Fc⊥x' = 650.00 psi  (CSI = 0.62)   ➜  OK
Beam Design 2024A56
2/19/2024 6
