Design Span (L): 19.75 ft.
Clear Span: 19.50 ft.
Total Span: 20.00 ft.
Selfweight: 86.4 lbs
Dist. Selfweight: 4.37 plf
Total Weight: 87.5 lbs
CL Beam Stability Factor 0.330 - - - - -
Beam Design 2024A53
2/19/2024 1
Beam Design 2024A53
2/19/2024 2
Volumetotal = N[A x (L + lb)] = 1 x [16.88 x (237.00 + 3)] x (12 in./ft.)3 = 2.34 ft3
Volumespan = N[A x L] = 1 x [16.88 x 237.00] x (12 in./ft.)3 = 2.31 ft3
Total Weight (WT) = ρw x Volumetotal = 37.33 x 2.34 = 87.5 lbs
Self Weight (WS) = ρw x Volumespan = 37.33 x 2.31 = 86.4 lbs
ws = 4.37 plf
19.75 ft.
19.50 ft.
1793.75 lbs
1793.75 lbs
Beam Design 2024A53
2/19/2024 3
lu = Unbraced Length = 19.750 ft.
lu/d = = 21.07
le = 1.63lu + 3d = 1.63(237.0) + 3(11.25) = 420.06 in. = 35.00 ft.  (NDS Table 3.3.3)
Rb = = 45.83
 Rb = 45.83 < 50   ➜  OK
Beam Design 2024A53
2/19/2024 4
FbE = = 291.39 psi
Fbx* = Fbx(CD)(CM)(Ct)(CF)(Ci)(Cr) = (750)(1.15)(1)(1)(1)(1)(1) = 862.50 psi
CL =   = 0.330
Fbx' = (750)(1.15)(1)(1)(0.330)(1)(1)(1) = 284.4 psi
fb = = 3317.0 psi
 fb = 3317.0 psi > Fbx' = 284.4 psi  (CSI = 11.66)   ➜  NG
fv* = = 142.50 psi
 fv* = 142.50 psi < Fvx' = 201.25 psi  (CSI = 0.71)   ➜  OK
fv = = 157.45 psi
 fv = 157.45 psi < Fvx' = 201.25 psi  (CSI = 0.78)   ➜  OK
Beam Design 2024A53
2/19/2024 5
ΔLL = = 1.37 in.
(L/d)LL = 237.00 / 1.37 = 173
 ΔLL = 1.37 in = L/173 > L/360   ➜  NG
ΔTL = = 2.46 in.
(L/d)TL = 237.00 / 2.46 = 96
 ΔTL = 2.46 in = L/96 > L/240   ➜  NG
fc⊥ = = 398.6 psi
 fc⊥ = 398.6 psi < Fc⊥x' = 565.00 psi  (CSI = 0.71)   ➜  OK
Beam Design 2024A53
2/19/2024 6
