Design Span (L): 19.75 ft.
Clear Span: 19.50 ft.
Total Span: 20.00 ft.
Live Load: 40 plf
Dead Load: 15 plf
Selfweight: 142.1 lbs
Dist. Selfweight: 7.19 plf
Total Weight: 143.9 lbs
Beam Design Coker 2024A508
12/31/2024 1
12/31/2024 2
Volumetotal = N[A x (L + lb)] = 2 x [13.88 x (237.00 + 3)] x (12 in./ft.)3 = 3.85 ft3
Volumespan = N[A x L] = 2 x [13.88 x 237.00] x (12 in./ft.)3 = 3.81 ft3
Total Weight (WT) = ρw x Volumetotal = 37.33 x 3.85 = 143.9 lbs
Self Weight (WS) = ρw x Volumespan = 37.33 x 3.81 = 142.1 lbs
40 plf
15 plf
ws = 7.19 plf
19.75 ft.
19.50 ft.
621.94 lbs
621.94 lbs
12/31/2024 3
Fbx' = (800)(1.15)(1)(1)(1)(1)(1)(1.15) = 1058.0 psi
fb = = 850.6 psi
 fb = 850.6 psi < Fbx' = 1058.0 psi  (CSI = 0.80)   ➜  OK
12/31/2024 4
fv* = = 30.61 psi
 fv* = 30.61 psi < Fvx' = 201.25 psi  (CSI = 0.15)   ➜  OK
fv = = 33.20 psi
 fv = 33.20 psi < Fvx' = 201.25 psi  (CSI = 0.16)   ➜  OK
12/31/2024 5
ΔLL = = 0.49 in.
(L/d)LL = 237.00 / 0.49 = 479
 ΔLL = 0.49 in = L/479 < L/360   ➜  OK
ΔTL = = 0.77 in.
(L/d)TL = 237.00 / 0.77 = 308
 ΔTL = 0.77 in = L/308 < L/240   ➜  OK
fc⊥ = = 69.1 psi
 fc⊥ = 69.1 psi < Fc⊥x' = 565.00 psi  (CSI = 0.12)   ➜  OK
12/31/2024 6
