Grade: 24F-V3 1.8E SP/SP
Size: 3.5 x 8.25
Design Span (L): 9.75 ft.
Clear Span: 9.50 ft.
Total Span: 10.00 ft.
Live Load: 300 plf
Selfweight: 72.1 lbs
Dist. Selfweight: 7.40 plf
Total Weight: 74.0 lbs
Beam Design 2024A506
12/26/2024 1
d = 8.250 in.
A = 3.500 x 8.250 = 28.88 in.2
Sx = (3.500)(8.250)2/6 = 39.70 in.3
Sy = (3.500)2(8.250)/6 = 16.84 in.3
Ix = (3.500)(8.250)3/12 = 163.78 in.4
Iy = (3.500)3(8.250)/12 = 29.48 in.4
12/26/2024 2
= 36.89 lbs/ft3
Volumetotal = N[A x (L + lb)] = 1 x [28.88 x (117.00 + 3)] x (12 in./ft.)3 = 2.01 ft3
Volumespan = N[A x L] = 1 x [28.88 x 117.00] x (12 in./ft.)3 = 1.96 ft3
Total Weight (WT) = ρw x Volumetotal = 36.89 x 2.01 = 74.0 lbs
Self Weight (WS) = ρw x Volumespan = 36.89 x 1.96 = 72.1 lbs
Distributed Self Weight (ws) = = 7.40 plf
300 plf
  ws = 7.40 plf
9.75 ft.
9.50 ft.
10.00 ft.
1911.99 lbs
1911.99 lbs
12/26/2024 3
fb = = 1373.4 psi
 fb = 1373.4 psi < Fbx' = 2400.0 psi  (CSI = 0.57)   ➜  OK
12/26/2024 4
fv* = = 83.18 psi
 fv* = 83.18 psi < Fvx' = 300.00 psi  (CSI = 0.28)   ➜  OK
fv = = 96.84 psi
 fv = 96.84 psi < Fvx' = 300.00 psi  (CSI = 0.32)   ➜  OK
12/26/2024 5
ΔLL = = 0.21 in.
(L/d)LL = 117.00 / 0.21 = 565
 ΔLL = 0.21 in = L/565 < L/360   ➜  OK
ΔTL = = 0.26 in.
(L/d)TL = 117.00 / 0.26 = 444
 ΔTL = 0.26 in = L/444 < L/240   ➜  OK
fc⊥ = = 182.1 psi
 fc⊥ = 182.1 psi < Fc⊥x' = 740.00 psi  (CSI = 0.25)   ➜  OK
12/26/2024 6
