Beam Design - TC Powwow Arbour
Size: 5.5 x 16.5
Design Span (L): 24.50 ft.
Clear Span: 24.00 ft.
Total Span: 25.00 ft.
Live Load: 312 plf
Dead Load: 144 plf
Selfweight: 521.3 lbs
Dist. Selfweight: 21.28 plf
Total Weight: 531.9 lbs
CV Volume Factor 0.947b - - - - -
Beam Design 2024A503
12/16/2024 1
d = 16.500 in.
12/16/2024 2
Volumetotal = N[A x (L + lb)] = 1 x [90.75 x (294.00 + 6)] x (12 in./ft.)3 = 15.76 ft3
Volumespan = N[A x L] = 1 x [90.75 x 294.00] x (12 in./ft.)3 = 15.44 ft3
Total Weight (WT) = ρw x Volumetotal = 33.76 x 15.76 = 531.9 lbs
Self Weight (WS) = ρw x Volumespan = 33.76 x 15.44 = 521.3 lbs
312 plf
144 plf
  ws = 21.28 plf
24.50 ft.
24.00 ft.
25.00 ft.
5965.96 lbs
5965.96 lbs
12/16/2024 3
CV = = 0.947
CV = 0.947 < CL = 1
Fbx' = (2400)(1.15)(1)(1)(0.947) = 2614.1 psi
fb = = 1721.9 psi
 fb = 1721.9 psi < Fbx' = 2614.1 psi  (CSI = 0.66)   ➜  OK
12/16/2024 4
fv* = = 85.79 psi
 fv* = 85.79 psi < Fvx' = 304.75 psi  (CSI = 0.28)   ➜  OK
fv = = 96.64 psi
 fv = 96.64 psi < Fvx' = 304.75 psi  (CSI = 0.32)   ➜  OK
12/16/2024 5
ΔLL = = 0.68 in.
(L/d)LL = 294.00 / 0.68 = 431
 ΔLL = 0.68 in = L/431 < L/360   ➜  OK
ΔTL = = 1.04 in.
(L/d)TL = 294.00 / 1.04 = 282
 ΔTL = 1.04 in = L/282 < L/240   ➜  OK
fc⊥ = = 180.8 psi
 fc⊥ = 180.8 psi < Fc⊥x' = 650.00 psi  (CSI = 0.28)   ➜  OK
12/16/2024 6
