Grade: SP No.1
Design Span (L): 13.25 ft.
Clear Span: 13.00 ft.
Total Span: 13.50 ft.
Live Load: 0 plf
Dead Load: 30 plf
Selfweight: 56.7 lbs
Dist. Selfweight: 4.28 plf
Total Weight: 57.7 lbs
Beam Design 2024A5
1/8/2024 1
SP No.1 1350 875 175 565 1550 1600000 580000 0.55
Beam Design 2024A5
1/8/2024 2
Volumetotal = N[A x (L + lb)] = 2 x [8.25 x (159.00 + 3)] x (12 in./ft.)3 = 1.55 ft3
Volumespan = N[A x L] = 2 x [8.25 x 159.00] x (12 in./ft.)3 = 1.52 ft3
Total Weight (WT) = ρw x Volumetotal = 37.33 x 1.55 = 57.7 lbs
Self Weight (WS) = ρw x Volumespan = 37.33 x 1.52 = 56.7 lbs
Distributed Self Weight (ws) = = 4.28 plf
0 plf
30 plf
ws = 4.28 plf
13.25 ft.
13.00 ft.
13.50 ft.
231.37 lbs
231.37 lbs
Beam Design 2024A5
1/8/2024 3
Fbx' = (1350)(0.9)(1)(1)(1)(1)(1)(1) = 1215.0 psi
fb = = 596.8 psi
 fb = 596.8 psi < Fbx' = 1215.0 psi  (CSI = 0.49)   ➜  OK
Beam Design 2024A5
1/8/2024 4
Fvx' = (175)(0.9)(1)(1)(1) = 157.50 psi
fv* = = 19.22 psi
 fv* = 19.22 psi < Fvx' = 157.50 psi  (CSI = 0.12)   ➜  OK
fv = = 20.64 psi
 fv = 20.64 psi < Fvx' = 157.50 psi  (CSI = 0.13)   ➜  OK
Beam Design 2024A5
1/8/2024 5
ΔLL = = 0.00 in.
(L/d)LL = 159.00 / 0.00 = ∞
ΔTL = = 0.36 in.
(L/d)TL = 159.00 / 0.36 = 445
 ΔTL = 0.36 in = L/445 < L/240   ➜  OK
fc⊥ = = 25.7 psi
 fc⊥ = 25.7 psi < Fc⊥x' = 565.00 psi  (CSI = 0.05)   ➜  OK
Beam Design 2024A5
1/8/2024 6
