Beam Design - TC Powwow Arbour
Grade: DF SS
Size: 4 x 16
Design Span (L): 24.50 ft.
Clear Span: 24.00 ft.
Total Span: 25.00 ft.
Live Load: 312 plf
Dead Load: 144 plf
Selfweight: 611.0 lbs
Dist. Selfweight: 24.94 plf
Total Weight: 623.5 lbs
Beam Design 2024A496
12/16/2024 1
d = 15.000 in.
12/16/2024 2
Volumetotal = N[A x (L + lb)] = 2 x [52.50 x (294.00 + 6)] x (12 in./ft.)3 = 18.23 ft3
Volumespan = N[A x L] = 2 x [52.50 x 294.00] x (12 in./ft.)3 = 17.86 ft3
Total Weight (WT) = ρw x Volumetotal = 34.20 x 18.23 = 623.5 lbs
Self Weight (WS) = ρw x Volumespan = 34.20 x 17.86 = 611.0 lbs
Distributed Self Weight (ws) = = 24.94 plf
312 plf
144 plf
ws = 24.94 plf
24.50 ft.
24.00 ft.
25.00 ft.
6011.75 lbs
6011.75 lbs
12/16/2024 3
Fbx' = (1500)(1.15)(1)(1)(1)(1)(1)(1) = 1725.0 psi
fb = = 1649.6 psi
 fb = 1649.6 psi < Fbx' = 1725.0 psi  (CSI = 0.96)   ➜  OK
12/16/2024 4
fv* = = 75.58 psi
 fv* = 75.58 psi < Fvx' = 207.00 psi  (CSI = 0.37)   ➜  OK
fv = = 84.16 psi
 fv = 84.16 psi < Fvx' = 207.00 psi  (CSI = 0.41)   ➜  OK
12/16/2024 5
ΔLL = = 0.68 in.
(L/d)LL = 294.00 / 0.68 = 435
 ΔLL = 0.68 in = L/435 < L/360   ➜  OK
ΔTL = = 1.04 in.
(L/d)TL = 294.00 / 1.04 = 282
 ΔTL = 1.04 in = L/282 < L/240   ➜  OK
fc⊥ = = 143.1 psi
 fc⊥ = 143.1 psi < Fc⊥x' = 625.00 psi  (CSI = 0.23)   ➜  OK
12/16/2024 6
