Beam Design - TC Powwow Arbour
Size: 5.5 x 15
Design Span (L): 26.50 ft.
Clear Span: 26.00 ft.
Total Span: 27.00 ft.
Live Load: 200 plf
Dead Load: 80 plf
Selfweight: 512.6 lbs
Dist. Selfweight: 19.34 plf
Total Weight: 522.2 lbs
CV Volume Factor 0.949b - - - - -
Beam Design 2024A495
12/16/2024 1
d = 15.000 in.
A = 5.500 x 15.000 = 82.50 in.2
Sx = (5.500)(15.000)2/6 = 206.25 in.3
Sy = (5.500)2(15.000)/6 = 75.63 in.3
Ix = (5.500)(15.000)3/12 = 1546.88 in.4
Iy = (5.500)3(15.000)/12 = 207.97 in.4
12/16/2024 2
Volumetotal = N[A x (L + lb)] = 1 x [82.50 x (318.00 + 6)] x (12 in./ft.)3 = 15.47 ft3
Volumespan = N[A x L] = 1 x [82.50 x 318.00] x (12 in./ft.)3 = 15.18 ft3
Total Weight (WT) = ρw x Volumetotal = 33.76 x 15.47 = 522.2 lbs
Self Weight (WS) = ρw x Volumespan = 33.76 x 15.18 = 512.6 lbs
Distributed Self Weight (ws) = = 19.34 plf
200 plf
80 plf
  ws = 19.34 plf
26.50 ft.
26.00 ft.
27.00 ft.
4041.12 lbs
4041.12 lbs
12/16/2024 3
CV = = 0.949
CV = 0.949 < CL = 1
Fbx' = (2400)(1.15)(1)(1)(0.949) = 2618.5 psi
fb = = 1528.8 psi
 fb = 1528.8 psi < Fbx' = 2618.5 psi  (CSI = 0.58)   ➜  OK
12/16/2024 4
fv* = = 65.31 psi
 fv* = 65.31 psi < Fvx' = 304.75 psi  (CSI = 0.21)   ➜  OK
fv = = 72.11 psi
 fv = 72.11 psi < Fvx' = 304.75 psi  (CSI = 0.24)   ➜  OK
12/16/2024 5
ΔLL = = 0.80 in.
(L/d)LL = 318.00 / 0.80 = 399
 ΔLL = 0.80 in = L/399 < L/360   ➜  OK
ΔTL = = 1.19 in.
(L/d)TL = 318.00 / 1.19 = 267
 ΔTL = 1.19 in = L/267 < L/240   ➜  OK
fc⊥ = = 122.5 psi
 fc⊥ = 122.5 psi < Fc⊥x' = 650.00 psi  (CSI = 0.19)   ➜  OK
12/16/2024 6
