Size: 3.125 x 12
Design Span (L): 12.25 ft.
Clear Span: 12.00 ft.
Total Span: 12.50 ft.
Live Load: 250 plf
Dead Load: 750 plf
Selfweight: 107.7 lbs
Dist. Selfweight: 8.79 plf
Total Weight: 109.9 lbs
Lateral Support: 4' o/c
CL Beam Stability Factor 0.977 - - - - -
Beam Design 2024A49
2/12/2024 1
b = 3.125 in.
Beam Design 2024A49
2/12/2024 2
Volumetotal = N[A x (L + lb)] = 1 x [37.50 x (147.00 + 3)] x (12 in./ft.)3 = 3.26 ft3
Volumespan = N[A x L] = 1 x [37.50 x 147.00] x (12 in./ft.)3 = 3.19 ft3
Total Weight (WT) = ρw x Volumetotal = 33.76 x 3.26 = 109.9 lbs
Self Weight (WS) = ρw x Volumespan = 33.76 x 3.19 = 107.7 lbs
250 plf
750 plf
  ws = 8.79 plf
12.25 ft.
12.50 ft.
6304.95 lbs
6304.95 lbs
Beam Design 2024A49
2/12/2024 3
lu = Unbraced Length = 4 ft.
lu/d = = 4.00
Rb = = 11.02
 Rb = 11.02 < 50   ➜  OK
Beam Design 2024A49
2/12/2024 4
FbE = = 8394.80 psi
CL =   = 0.977
CL = 0.977 < CV = 1.0
Fbx' = (2400)(1.15)(1)(1)(0.977) = 2696.2 psi
fb = = 3027.6 psi
 fb = 3027.6 psi > Fbx' = 2696.2 psi  (CSI = 1.12)   ➜  NG
fv* = = 206.80 psi
Beam Design 2024A49
2/12/2024 5
 fv* = 206.80 psi < Fvx' = 304.75 psi  (CSI = 0.68)   ➜  OK
fv = = 247.15 psi
 fv = 247.15 psi < Fvx' = 304.75 psi  (CSI = 0.81)   ➜  OK
ΔLL = = 0.16 in.
(L/d)LL = 147.00 / 0.16 = 940
 ΔLL = 0.16 in = L/940 < L/360   ➜  OK
ΔTL = = 0.63 in.
(L/d)TL = 147.00 / 0.63 = 233
 ΔTL = 0.63 in = L/233 > L/240   ➜  NG
Beam Design 2024A49
2/12/2024 6
fc⊥ = = 672.5 psi
 fc⊥ = 672.5 psi > Fc⊥x' = 650.00 psi  (CSI = 1.03)   ➜  NG
Beam Design 2024A49
2/12/2024 7
