Design Span (L): 26.50 ft.
Clear Span: 26.00 ft.
Total Span: 27.00 ft.
Live Load: 200 plf
Dead Load: 80 plf
Selfweight: 87.3 lbs
Dist. Selfweight: 3.30 plf
Total Weight: 89.0 lbs
Beam Design 2024A486
12/16/2024 1
12/16/2024 2
Volumetotal = N[A x (L + lb)] = 1 x [13.88 x (318.00 + 6)] x (12 in./ft.)3 = 2.60 ft3
Volumespan = N[A x L] = 1 x [13.88 x 318.00] x (12 in./ft.)3 = 2.55 ft3
Total Weight (WT) = ρw x Volumetotal = 34.20 x 2.60 = 89.0 lbs
Self Weight (WS) = ρw x Volumespan = 34.20 x 2.55 = 87.3 lbs
200 plf
80 plf
ws = 3.30 plf
26.50 ft.
26.00 ft.
27.00 ft.
3824.49 lbs
3824.49 lbs
12/16/2024 3
fb = = 13950.8 psi
 fb = 13950.8 psi > Fbx' = 1138.5 psi  (CSI = 12.25)   ➜  NG
12/16/2024 4
fv* = = 382.19 psi
 fv* = 382.19 psi > Fvx' = 207.00 psi  (CSI = 1.85)   ➜  NG
fv = = 405.80 psi
 fv = 405.80 psi > Fvx' = 207.00 psi  (CSI = 1.96)   ➜  NG
12/16/2024 5
ΔLL = = 14.02 in.
(L/d)LL = 318.00 / 14.02 = 23
 ΔLL = 14.02 in = L/23 > L/360   ➜  NG
ΔTL = = 19.86 in.
(L/d)TL = 318.00 / 19.86 = 16
 ΔTL = 19.86 in = L/16 > L/240   ➜  NG
fc⊥ = = 424.9 psi
 fc⊥ = 424.9 psi < Fc⊥x' = 625.00 psi  (CSI = 0.68)   ➜  OK
12/16/2024 6
