Design Span (L): 16.50 ft.
Clear Span: 16.00 ft.
Total Span: 17.00 ft.
Selfweight: 54.4 lbs
Dist. Selfweight: 3.30 plf
Total Weight: 56.0 lbs
Beam Design 2024A484
12/10/2024 1
12/10/2024 2
Volumetotal = N[A x (L + lb)] = 1 x [13.88 x (198.00 + 6)] x (12 in./ft.)3 = 1.64 ft3
Volumespan = N[A x L] = 1 x [13.88 x 198.00] x (12 in./ft.)3 = 1.59 ft3
Total Weight (WT) = ρw x Volumetotal = 34.20 x 1.64 = 56.0 lbs
Self Weight (WS) = ρw x Volumespan = 34.20 x 1.59 = 54.4 lbs
ws = 3.30 plf
16.50 ft.
17.00 ft.
1515.51 lbs
1515.51 lbs
12/10/2024 3
fb = = 3403.9 psi
 fb = 3403.9 psi > Fbx' = 1138.5 psi  (CSI = 2.99)   ➜  NG
12/10/2024 4
fv* = = 144.16 psi
 fv* = 144.16 psi < Fvx' = 207.00 psi  (CSI = 0.70)   ➜  OK
fv = = 159.02 psi
 fv = 159.02 psi < Fvx' = 207.00 psi  (CSI = 0.77)   ➜  OK
12/10/2024 5
ΔLL = = 1.05 in.
(L/d)LL = 198.00 / 1.05 = 188
 ΔLL = 1.05 in = L/188 > L/360   ➜  NG
ΔTL = = 1.88 in.
(L/d)TL = 198.00 / 1.88 = 105
 ΔTL = 1.88 in = L/105 > L/240   ➜  NG
fc⊥ = = 168.4 psi
 fc⊥ = 168.4 psi < Fc⊥x' = 625.00 psi  (CSI = 0.27)   ➜  OK
12/10/2024 6
