Grade: DF No.1
Design Span (L): 6.50 ft.
Clear Span: 6.25 ft.
Total Span: 6.75 ft.
Live Load: 520 plf
Dead Load: 130 plf
Selfweight: 16.8 lbs
Dist. Selfweight: 2.58 plf
Total Weight: 17.4 lbs
Orientation: Horizontal
Beam Design 2024A483
12/10/2024 1
12/10/2024 2
Volumetotal = N[A x (L + lb)] = 1 x [10.88 x (78.00 + 3)] x (12 in./ft.)3 = 0.51 ft3
Volumespan = N[A x L] = 1 x [10.88 x 78.00] x (12 in./ft.)3 = 0.49 ft3
Total Weight (WT) = ρw x Volumetotal = 34.20 x 0.51 = 17.4 lbs
Self Weight (WS) = ρw x Volumespan = 34.20 x 0.49 = 16.8 lbs
520 plf
130 plf
ws = 2.58 plf
6.50 ft.
6.25 ft.
6.75 ft.
2202.47 lbs
2202.47 lbs
12/10/2024 3
Fby' = (1000)(1.00)(1)(1)(1)(1.2)(1.15)(1)(1.15) = 1587.0 psi
fb = = 15211.9 psi
 fb = 15211.9 psi > Fby' = 1587.0 psi  (CSI = 9.59)   ➜  NG
12/10/2024 4
Fvy' = (180)(1.00)(1)(1)(1) = 180.00 psi
fv* = = 281.29 psi
 fv* = 281.29 psi > Fvy' = 180.00 psi  (CSI = 1.56)   ➜  NG
fv = = 292.54 psi
 fv = 292.54 psi > Fvy' = 180.00 psi  (CSI = 1.63)   ➜  NG
Ey' = Ey(CM)(Ct)(Ci) = 1700000(1)(1)(1) = 1700000 psi
12/10/2024 5
ΔLL = = 6.03 in.
(L/d)LL = 78.00 / 6.03 = 13
 ΔLL = 6.03 in = L/13 > L/240   ➜  NG
ΔTL = = 7.56 in.
(L/d)TL = 78.00 / 7.56 = 10
 ΔTL = 7.56 in = L/10 > L/180   ➜  NG
Ab = d x lb = 7.25 x 3 = 21.75 in2
fc⊥ = = 101.3 psi
 fc⊥ = 101.3 psi < Fc⊥y' = 625.00 psi  (CSI = 0.16)   ➜  OK
12/10/2024 6
