Size: 5.125 x 18
Design Span (L): 24.25 ft.
Clear Span: 24.00 ft.
Total Span: 24.50 ft.
Live Load: 50 plf
Dead Load: 15 plf
Selfweight: 524.5 lbs
Dist. Selfweight: 21.63 plf
Total Weight: 529.9 lbs
CV Volume Factor 0.947b - - - - -
Beam Design 2024A481
11/27/2024 1
b = 5.125 in.
d = 18.000 in.
A = 5.125 x 18.000 = 92.25 in.2
Sx = (5.125)(18.000)2/6 = 276.75 in.3
Sy = (5.125)2(18.000)/6 = 78.80 in.3
Ix = (5.125)(18.000)3/12 = 2490.75 in.4
Iy = (5.125)3(18.000)/12 = 201.92 in.4
11/27/2024 2
Volumetotal = N[A x (L + lb)] = 1 x [92.25 x (291.00 + 3)] x (12 in./ft.)3 = 15.70 ft3
Volumespan = N[A x L] = 1 x [92.25 x 291.00] x (12 in./ft.)3 = 15.54 ft3
Total Weight (WT) = ρw x Volumetotal = 33.76 x 15.70 = 529.9 lbs
Self Weight (WS) = ρw x Volumespan = 33.76 x 15.54 = 524.5 lbs
Distributed Self Weight (ws) = = 21.63 plf
50 plf
15 plf
  ws = 21.63 plf
24.25 ft.
24.00 ft.
24.50 ft.
1061.20 lbs
1061.20 lbs
11/27/2024 3
CV = = 0.947
CV = 0.947 < CL = 1
Fbx' = (2400)(1.15)(1)(1)(0.947) = 2612.5 psi
fb = = 276.1 psi
 fb = 276.1 psi < Fbx' = 2612.5 psi  (CSI = 0.11)   ➜  OK
11/27/2024 4
fv* = = 14.97 psi
 fv* = 14.97 psi < Fvx' = 304.75 psi  (CSI = 0.05)   ➜  OK
fv = = 17.08 psi
 fv = 17.08 psi < Fvx' = 304.75 psi  (CSI = 0.06)   ➜  OK
11/27/2024 5
ΔLL = = 0.09 in.
(L/d)LL = 291.00 / 0.09 = 3353
 ΔLL = 0.09 in = L/3353 < L/360   ➜  OK
ΔTL = = 0.15 in.
(L/d)TL = 291.00 / 0.15 = 1936
 ΔTL = 0.15 in = L/1936 < L/240   ➜  OK
fc⊥ = = 69.0 psi
 fc⊥ = 69.0 psi < Fc⊥x' = 650.00 psi  (CSI = 0.11)   ➜  OK
11/27/2024 6
