Size: 3.5 x 12
Design Span (L): 8.25 ft.
Clear Span: 8.00 ft.
Total Span: 8.50 ft.
Live Load: 6933 lbs
Dead Load: 2133 lbs
Selfweight: 81.2 lbs
Dist. Selfweight: 9.85 plf
Total Weight: 83.7 lbs
Beam Design 2024A474
11/15/2024 1
11/15/2024 2
Volumetotal = N[A x (L + lb)] = 1 x [42.00 x (99.00 + 3)] x (12 in./ft.)3 = 2.48 ft3
Volumespan = N[A x L] = 1 x [42.00 x 99.00] x (12 in./ft.)3 = 2.41 ft3
Total Weight (WT) = ρw x Volumetotal = 33.76 x 2.48 = 83.7 lbs
Self Weight (WS) = ρw x Volumespan = 33.76 x 2.41 = 81.2 lbs
6933 lbs
2133 lbs
  ws = 9.85 plf
8.25 ft.
8.50 ft.
4574.85 lbs
4574.85 lbs
11/15/2024 3
fb = = 2683.2 psi
 fb = 2683.2 psi < Fbx' = 2760.0 psi  (CSI = 0.97)   ➜  OK
11/15/2024 4
fv* = = 162.99 psi
 fv* = 162.99 psi < Fvx' = 304.75 psi  (CSI = 0.53)   ➜  OK
fv = = 163.34 psi
 fv = 163.34 psi < Fvx' = 304.75 psi  (CSI = 0.54)   ➜  OK
11/15/2024 5
ΔLL =   =   = 0.15 in.
(L/d)LL = 99.00 / 0.15 = 641
 ΔLL = 0.15 in = L/641 < L/360   ➜  OK
ΔTL =   =   = 0.20 in.
(L/d)TL = 99.00 / 0.20 = 487
 ΔTL = 0.20 in = L/487 < L/240   ➜  OK
fc⊥ = = 435.7 psi
 fc⊥ = 435.7 psi < Fc⊥x' = 650.00 psi  (CSI = 0.67)   ➜  OK
11/15/2024 6
