Size: 2.5 x 6
Design Span (L): 15.50 ft.
Clear Span: 14.00 ft.
Total Span: 17.00 ft.
Bearing (lb): 18 in.
Live Load: 1000 lbs
Dead Load: 1000 lbs
Selfweight: 54.5 lbs
Dist. Selfweight: 3.52 plf
Total Weight: 59.8 lbs
Load Duration: 1.25
Orientation: Horizontal
Cfu Flat Use Factor 1.190c - - - - -
Beam Design 2024A47
2/10/2024 1
b = 2.500 in.
d = 6.000 in.
A = 2.500 x 6.000 = 15.00 in.2
Sx = (2.500)(6.000)2/6 = 15.00 in.3
Sy = (2.500)2(6.000)/6 = 6.25 in.3
Ix = (2.500)(6.000)3/12 = 45.00 in.4
Iy = (2.500)3(6.000)/12 = 7.81 in.4
Beam Design 2024A47
2/10/2024 2
Volumetotal = N[A x (L + lb)] = 1 x [15.00 x (186.00 + 18)] x (12 in./ft.)3 = 1.77 ft3
Volumespan = N[A x L] = 1 x [15.00 x 186.00] x (12 in./ft.)3 = 1.61 ft3
Total Weight (WT) = ρw x Volumetotal = 33.76 x 1.77 = 59.8 lbs
Self Weight (WS) = ρw x Volumespan = 33.76 x 1.61 = 54.5 lbs
1000 lbs
1000 lbs
  ws = 3.52 plf
15.50 ft.
17.00 ft.
1029.89 lbs
1029.89 lbs
Beam Design 2024A47
2/10/2024 3
Cfu = = 1.190
Fby' = (1450)(1.25)(1)(1)(1)(1.190) = 2157.6 psi
fb = = 15082.8 psi
 fb = 15082.8 psi > Fby' = 2157.6 psi  (CSI = 6.99)   ➜  NG
Beam Design 2024A47
2/10/2024 4
Fvy' = (230)(1.25)(1)(1) = 331.25 psi
fv* = = 102.65 psi
 fv* = 102.65 psi < Fvy' = 287.50 psi  (CSI = 0.36)   ➜  OK
fv = = 102.73 psi
 fv = 102.73 psi < Fvy' = 287.50 psi  (CSI = 0.36)   ➜  OK
Ey' = Ey(CM)(Ct) = 1600000(1)(1) = 1600000 psi
Beam Design 2024A47
2/10/2024 5
ΔLL =   =   = 10.72 in.
(L/d)LL = 186.00 / 10.72 = 17
 ΔLL = 10.72 in = L/17 > L/360   ➜  NG
ΔTL =   =   = 21.81 in.
(L/d)TL = 186.00 / 21.81 = 9
 ΔTL = 21.81 in = L/9 > L/240   ➜  NG
Fc⊥y' = (560)(1)(1) = 560.00 psi
Ab = d x lb = 6 x 18 = 108.00 in2
fc⊥ = = 9.5 psi
 fc⊥ = 9.5 psi < Fc⊥y' = 560.00 psi  (CSI = 0.02)   ➜  OK
Beam Design 2024A47
2/10/2024 6
