Beam Design - WESH MIAH
Size: 4 x 4
Design Span (L): 4.00 ft.
Clear Span: 3.75 ft.
Total Span: 4.25 ft.
Selfweight: 11.6 lbs
Dist. Selfweight: 2.91 plf
Total Weight: 12.4 lbs
Beam Design MOIN AWAIS IBADAN NIGERIA 3
11/3/2024 1
d = 3.500 in.
11/3/2024 2
Volumetotal = N[A x (L + lb)] = 1 x [12.25 x (48.00 + 3)] x (12 in./ft.)3 = 0.36 ft3
Volumespan = N[A x L] = 1 x [12.25 x 48.00] x (12 in./ft.)3 = 0.34 ft3
Total Weight (WT) = ρw x Volumetotal = 34.20 x 0.36 = 12.4 lbs
Self Weight (WS) = ρw x Volumespan = 34.20 x 0.34 = 11.6 lbs
ws = 2.91 plf
4.00 ft.
3.75 ft.
4.25 ft.
378.06 lbs
378.06 lbs
11/3/2024 3
Fbx' = (900)(1.00)(1)(1)(1)(1.5)(1)(1) = 1350.0 psi
fb = = 597.5 psi
 fb = 597.5 psi < Fbx' = 1350.0 psi  (CSI = 0.44)   ➜  OK
11/3/2024 4
fv* = = 37.22 psi
 fv* = 37.22 psi < Fvx' = 180.00 psi  (CSI = 0.21)   ➜  OK
fv = = 43.57 psi
 fv = 43.57 psi < Fvx' = 180.00 psi  (CSI = 0.24)   ➜  OK
11/3/2024 5
ΔLL = = 0.03 in.
(L/d)LL = 48.00 / 0.03 = 1667
 ΔLL = 0.03 in = L/1667 < L/360   ➜  OK
ΔTL = = 0.05 in.
(L/d)TL = 48.00 / 0.05 = 937
 ΔTL = 0.05 in = L/937 < L/240   ➜  OK
fc⊥ = = 36.0 psi
 fc⊥ = 36.0 psi < Fc⊥x' = 625.00 psi  (CSI = 0.06)   ➜  OK
11/3/2024 6
