Grade: SPF No.2
Design Span (L): 10.40 ft.
Clear Span: 10.17 ft.
Total Span: 10.63 ft.
Bearing (lb): 2.75 in.
Quantity (N): 4
Live Load: 0 plf
Dead Load: 232 plf
Selfweight: 95.3 lbs
Dist. Selfweight: 9.16 plf
Total Weight: 97.4 lbs
Incised Lumber: Yes
Beam Design 2024A466
11/2/2024 1
11/2/2024 2
= 30.34 lbs/ft3
Volumetotal = N[A x (L + lb)] = 4 x [10.88 x (124.75 + 2.75)] x (12 in./ft.)3 = 3.21 ft3
Volumespan = N[A x L] = 4 x [10.88 x 124.75] x (12 in./ft.)3 = 3.14 ft3
Total Weight (WT) = ρw x Volumetotal = 30.34 x 3.21 = 97.4 lbs
Self Weight (WS) = ρw x Volumespan = 30.34 x 3.14 = 95.3 lbs
Distributed Self Weight (ws) = = 9.16 plf
0 plf
232 plf
ws = 9.16 plf
10.40 ft.
10.17 ft.
10.63 ft.
1281.20 lbs
1281.20 lbs
11/2/2024 3
Fbx' = (875)(0.9)(1)(1)(1)(1.2)(0.8)(1) = 756.0 psi
fb = = 743.8 psi
 fb = 743.8 psi < Fbx' = 756.0 psi  (CSI = 0.98)   ➜  OK
11/2/2024 4
Fvx' = (135)(0.9)(0.97)(1)(0.8) = 94.28 psi
fv* = = 38.20 psi
 fv* = 38.20 psi < Fvx' = 94.28 psi  (CSI = 0.41)   ➜  OK
fv = = 43.23 psi
 fv = 43.23 psi < Fvx' = 94.28 psi  (CSI = 0.46)   ➜  OK
Ex' = Ex(CM)(Ct)(Ci) = 1400000(0.9)(1)(0.95) = 1197000 psi
11/2/2024 5
ΔLL = = 0.00 in.
(L/d)LL = 124.75 / 0.00 = ∞
ΔTL = = 0.28 in.
(L/d)TL = 124.75 / 0.28 = 449
 ΔTL = 0.28 in = L/449 < L/240   ➜  OK
fc⊥ = = 77.6 psi
 fc⊥ = 77.6 psi < Fc⊥x' = 284.75 psi  (CSI = 0.27)   ➜  OK
11/2/2024 6
