Design Span (L): 4.25 ft.
Clear Span: 4.00 ft.
Total Span: 4.50 ft.
Live Load: 120 plf
Dead Load: 15 plf
Selfweight: 8.3 lbs
Dist. Selfweight: 1.96 plf
Total Weight: 8.8 lbs
Beam Design 2024A463
10/28/2024 1
10/28/2024 2
Volumetotal = N[A x (L + lb)] = 1 x [8.25 x (51.00 + 3)] x (12 in./ft.)3 = 0.26 ft3
Volumespan = N[A x L] = 1 x [8.25 x 51.00] x (12 in./ft.)3 = 0.24 ft3
Total Weight (WT) = ρw x Volumetotal = 34.20 x 0.26 = 8.8 lbs
Self Weight (WS) = ρw x Volumespan = 34.20 x 0.24 = 8.3 lbs
120 plf
15 plf
ws = 1.96 plf
4.25 ft.
4.00 ft.
4.50 ft.
308.16 lbs
308.16 lbs
10/28/2024 3
fb = = 490.7 psi
 fb = 490.7 psi < Fbx' = 1345.5 psi  (CSI = 0.36)   ➜  OK
10/28/2024 4
fv* = = 41.50 psi
 fv* = 41.50 psi < Fvx' = 207.00 psi  (CSI = 0.20)   ➜  OK
fv = = 52.92 psi
 fv = 52.92 psi < Fvx' = 207.00 psi  (CSI = 0.26)   ➜  OK
10/28/2024 5
ΔLL = = 0.03 in.
(L/d)LL = 51.00 / 0.03 = 1926
 ΔLL = 0.03 in = L/1926 < L/360   ➜  OK
ΔTL = = 0.03 in.
(L/d)TL = 51.00 / 0.03 = 1688
 ΔTL = 0.03 in = L/1688 < L/240   ➜  OK
fc⊥ = = 68.5 psi
 fc⊥ = 68.5 psi < Fc⊥x' = 625.00 psi  (CSI = 0.11)   ➜  OK
10/28/2024 6
