Beam Design - 2X6 JOIST
Design Span (L): 3.88 ft.
Clear Span: 3.75 ft.
Total Span: 4.00 ft.
Bearing (lb): 1.5 in.
Quantity (N): 8
Live Load: 120 plf
Dead Load: 10 plf
Selfweight: 60.7 lbs
Dist. Selfweight: 15.68 plf
Total Weight: 62.7 lbs
Beam Design Michael Lewallen 319 NE Cedar St 2407 NELSON DECK
10/24/2024 1
10/24/2024 2
Volumetotal = N[A x (L + lb)] = 8 x [8.25 x (46.50 + 1.5)] x (12 in./ft.)3 = 1.83 ft3
Volumespan = N[A x L] = 8 x [8.25 x 46.50] x (12 in./ft.)3 = 1.78 ft3
Total Weight (WT) = ρw x Volumetotal = 34.20 x 1.83 = 62.7 lbs
Self Weight (WS) = ρw x Volumespan = 34.20 x 1.78 = 60.7 lbs
Distributed Self Weight (ws) = = 15.68 plf
120 plf
10 plf
ws = 15.68 plf
3.88 ft.
3.75 ft.
4.00 ft.
291.35 lbs
291.35 lbs
10/24/2024 3
fb = = 54.2 psi
 fb = 54.2 psi < Fbx' = 1345.5 psi  (CSI = 0.04)   ➜  OK
10/24/2024 4
fv* = = 4.90 psi
 fv* = 4.90 psi < Fvx' = 207.00 psi  (CSI = 0.02)   ➜  OK
fv = = 6.41 psi
 fv = 6.41 psi < Fvx' = 207.00 psi  (CSI = 0.03)   ➜  OK
10/24/2024 5
ΔLL = = 0.00 in.
(L/d)LL = 46.50 / 0.00 = 20333
 ΔLL = 0.00 in = L/20333 < L/360   ➜  OK
ΔTL = = 0.00 in.
(L/d)TL = 46.50 / 0.00 = 16749
 ΔTL = 0.00 in = L/16749 < L/240   ➜  OK
fc⊥ = = 16.2 psi
 fc⊥ = 16.2 psi < Fc⊥x' = 625.00 psi  (CSI = 0.03)   ➜  OK
10/24/2024 6
