Grade: SPF No.1
Quantity (N): 4
Live Load: 462 plf
Dead Load: 120 plf
Selfweight: 160.3 lbs
Dist. Selfweight: 13.64 plf
Total Weight: 163.7 lbs
Beam Design 2024A451
10/24/2024 1
SPF No.1 875 450 135 425 1150 1400000 510000 0.42
10/24/2024 2
Volumetotal = N[A x (L + lb)] = 4 x [16.88 x (141.00 + 3)] x (12 in./ft.)3 = 5.63 ft3
Volumespan = N[A x L] = 4 x [16.88 x 141.00] x (12 in./ft.)3 = 5.51 ft3
Total Weight (WT) = ρw x Volumetotal = 29.10 x 5.63 = 163.7 lbs
Self Weight (WS) = ρw x Volumespan = 29.10 x 5.51 = 160.3 lbs
Distributed Self Weight (ws) = = 13.64 plf
462 plf
120 plf
ws = 13.64 plf
3573.84 lbs
3573.84 lbs
10/24/2024 3
fb = = 974.6 psi
 fb = 974.6 psi < Fbx' = 1006.2 psi  (CSI = 0.97)   ➜  OK
10/24/2024 4
fv* = = 65.35 psi
 fv* = 65.35 psi < Fvx' = 155.25 psi  (CSI = 0.42)   ➜  OK
fv = = 77.76 psi
 fv = 77.76 psi < Fvx' = 155.25 psi  (CSI = 0.50)   ➜  OK
10/24/2024 5
ΔLL = = 0.20 in.
(L/d)LL = 141.00 / 0.20 = 709
 ΔLL = 0.20 in = L/709 < L/240   ➜  OK
ΔTL = = 0.26 in.
(L/d)TL = 141.00 / 0.26 = 550
 ΔTL = 0.26 in = L/550 < L/180   ➜  OK
fc⊥ = = 198.5 psi
 fc⊥ = 198.5 psi < Fc⊥x' = 425.00 psi  (CSI = 0.47)   ➜  OK
10/24/2024 6
