Beam Design - Georgia Deck
Size: 3.5 x 15
Design Span (L): 20.50 ft.
Clear Span: 20.25 ft.
Total Span: 20.75 ft.
Live Load: 119.3 plf
Dead Load: 27 plf
Selfweight: 252.3 lbs
Dist. Selfweight: 12.31 plf
Total Weight: 255.4 lbs
Beam Design Moin Awais 911 Highland Ter NE, Atlanta , GA 30306 Deck
10/21/2024 1
d = 15.000 in.
10/21/2024 2
Volumetotal = N[A x (L + lb)] = 1 x [52.50 x (246.00 + 3)] x (12 in./ft.)3 = 7.57 ft3
Volumespan = N[A x L] = 1 x [52.50 x 246.00] x (12 in./ft.)3 = 7.47 ft3
Total Weight (WT) = ρw x Volumetotal = 33.76 x 7.57 = 255.4 lbs
Self Weight (WS) = ρw x Volumespan = 33.76 x 7.47 = 252.3 lbs
119.3 plf
27 plf
  ws = 12.31 plf
20.50 ft.
20.25 ft.
20.75 ft.
1645.57 lbs
1645.57 lbs
10/21/2024 3
fb = = 761.8 psi
 fb = 761.8 psi < Fbx' = 2760.0 psi  (CSI = 0.28)   ➜  OK
10/21/2024 4
fv* = = 40.79 psi
 fv* = 40.79 psi < Fvx' = 304.75 psi  (CSI = 0.13)   ➜  OK
fv = = 46.45 psi
 fv = 46.45 psi < Fvx' = 304.75 psi  (CSI = 0.15)   ➜  OK
10/21/2024 5
ΔLL = = 0.27 in.
(L/d)LL = 246.00 / 0.27 = 919
 ΔLL = 0.27 in = L/919 < L/360   ➜  OK
ΔTL = = 0.36 in.
(L/d)TL = 246.00 / 0.36 = 692
 ΔTL = 0.36 in = L/692 < L/240   ➜  OK
fc⊥ = = 156.7 psi
 fc⊥ = 156.7 psi < Fc⊥x' = 650.00 psi  (CSI = 0.24)   ➜  OK
10/21/2024 6
