Size: 2 x 4
Design Span (L): 1.25 ft.
Clear Span: 1.00 ft.
Total Span: 1.50 ft.
Live Load: 0 plf
Dead Load: 700 plf
Selfweight: 1.6 lbs
Dist. Selfweight: 1.25 plf
Total Weight: 1.9 lbs
Beam Design 2024A445
10/16/2024 1
d = 3.500 in.
A = 1.500 x 3.500 = 5.25 in.2
10/16/2024 2
Volumetotal = N[A x (L + lb)] = 1 x [5.25 x (15.00 + 3)] x (12 in./ft.)3 = 0.05 ft3
Volumespan = N[A x L] = 1 x [5.25 x 15.00] x (12 in./ft.)3 = 0.05 ft3
Total Weight (WT) = ρw x Volumetotal = 34.20 x 0.05 = 1.9 lbs
Self Weight (WS) = ρw x Volumespan = 34.20 x 0.05 = 1.6 lbs
Distributed Self Weight (ws) = = 1.25 plf
0 plf
700 plf
ws = 1.25 plf
1.25 ft.
1.00 ft.
1.50 ft.
525.94 lbs
525.94 lbs
10/16/2024 3
lu = Unbraced Length = 1.250 ft.
lu/d = = 4.29
le = 2.06lu = 2.06(15.0) = 30.90 in. = 2.58 ft.  (NDS Table 3.3.3)
Rb = = 6.93
 Rb = 6.93 < 50   ➜  OK
10/16/2024 4
FbE = = 14479.89 psi
Fbx* = Fbx(CD)(CM)(Ct)(CF)(Ci)(Cr) = (900)(0.9)(1)(1)(1.5)(1)(1) = 1215.00 psi
CL =   = 0.995
Fbx' = (900)(0.9)(1)(1)(0.995)(1.5)(1)(1) = 1209.5 psi
fb = = 536.7 psi
 fb = 536.7 psi < Fbx' = 1209.5 psi  (CSI = 0.44)   ➜  OK
fv* = = 66.79 psi
 fv* = 66.79 psi < Fvx' = 162.00 psi  (CSI = 0.41)   ➜  OK
fv = = 125.22 psi
 fv = 125.22 psi < Fvx' = 162.00 psi  (CSI = 0.77)   ➜  OK
10/16/2024 5
ΔLL = = 0.00 in.
(L/d)LL = 15.00 / 0.00 = ∞
ΔTL = = 0.00 in.
(L/d)TL = 15.00 / 0.00 = 3339
 ΔTL = 0.00 in = L/3339 < L/240   ➜  OK
fc⊥ = = 116.9 psi
 fc⊥ = 116.9 psi < Fc⊥x' = 625.00 psi  (CSI = 0.19)   ➜  OK
10/16/2024 6
