Beam Design - 4x8x8-00
Size: 4 x 8
Design Span (L): 7.75 ft.
Clear Span: 7.50 ft.
Total Span: 8.00 ft.
Live Load: 0 plf
Dead Load: 180 plf
Selfweight: 48.4 lbs
Dist. Selfweight: 6.25 plf
Total Weight: 50.0 lbs
Beam Design Ed Hultgren 1802 Whitecliff Way 002
10/15/2024 1
10/15/2024 2
Volumetotal = N[A x (L + lb)] = 1 x [25.38 x (93.00 + 3)] x (12 in./ft.)3 = 1.41 ft3
Volumespan = N[A x L] = 1 x [25.38 x 93.00] x (12 in./ft.)3 = 1.37 ft3
Total Weight (WT) = ρw x Volumetotal = 35.47 x 1.41 = 50.0 lbs
Self Weight (WS) = ρw x Volumespan = 35.47 x 1.37 = 48.4 lbs
Distributed Self Weight (ws) = = 6.25 plf
0 plf
180 plf
ws = 6.25 plf
7.75 ft.
7.50 ft.
745.00 lbs
745.00 lbs
10/15/2024 3
Fbx' = (900)(0.9)(0.85)(1)(1)(1.3)(1)(1) = 895.1 psi
fb = = 547.3 psi
 fb = 547.3 psi < Fbx' = 895.1 psi  (CSI = 0.61)   ➜  OK
10/15/2024 4
Fvx' = (180)(0.9)(0.97)(1)(1) = 157.14 psi
fv* = = 36.01 psi
 fv* = 36.01 psi < Fvx' = 157.14 psi  (CSI = 0.23)   ➜  OK
fv = = 42.66 psi
 fv = 42.66 psi < Fvx' = 157.14 psi  (CSI = 0.27)   ➜  OK
10/15/2024 5
ΔLL = = 0.00 in.
(L/d)LL = 93.00 / 0.00 = ∞
ΔTL = = 0.09 in.
(L/d)TL = 93.00 / 0.09 = 985
 ΔTL = 0.09 in = L/985 < L/120   ➜  OK
fc⊥ = = 71.0 psi
 fc⊥ = 71.0 psi < Fc⊥x' = 418.75 psi  (CSI = 0.17)   ➜  OK
10/15/2024 6
