Beam Design - 4x10x6-00
Size: 4 x 8
Design Span (L): 5.75 ft.
Clear Span: 5.50 ft.
Total Span: 6.00 ft.
Live Load: 0 plf
Dead Load: 180 plf
Selfweight: 35.9 lbs
Dist. Selfweight: 6.25 plf
Total Weight: 37.5 lbs
Notes: DL
Beam Design Ed Hultgren 1802 Whitecliff Way 001
10/15/2024 1
10/15/2024 2
Volumetotal = N[A x (L + lb)] = 1 x [25.38 x (69.00 + 3)] x (12 in./ft.)3 = 1.06 ft3
Volumespan = N[A x L] = 1 x [25.38 x 69.00] x (12 in./ft.)3 = 1.01 ft3
Total Weight (WT) = ρw x Volumetotal = 35.47 x 1.06 = 37.5 lbs
Self Weight (WS) = ρw x Volumespan = 35.47 x 1.01 = 35.9 lbs
Distributed Self Weight (ws) = = 6.25 plf
0 plf
180 plf
ws = 6.25 plf
5.75 ft.
5.50 ft.
558.75 lbs
558.75 lbs
10/15/2024 3
Fbx' = (900)(0.9)(0.85)(1)(1)(1.3)(1)(1) = 895.1 psi
fb = = 301.3 psi
 fb = 301.3 psi < Fbx' = 895.1 psi  (CSI = 0.34)   ➜  OK
10/15/2024 4
Fvx' = (180)(0.9)(0.97)(1)(1) = 157.14 psi
fv* = = 25.00 psi
 fv* = 25.00 psi < Fvx' = 157.14 psi  (CSI = 0.16)   ➜  OK
fv = = 31.65 psi
 fv = 31.65 psi < Fvx' = 157.14 psi  (CSI = 0.20)   ➜  OK
10/15/2024 5
ΔLL = = 0.00 in.
(L/d)LL = 69.00 / 0.00 = ∞
ΔTL = = 0.03 in.
(L/d)TL = 69.00 / 0.03 = 2411
 ΔTL = 0.03 in = L/2411 < L/120   ➜  OK
fc⊥ = = 53.2 psi
 fc⊥ = 53.2 psi < Fc⊥x' = 418.75 psi  (CSI = 0.13)   ➜  OK
10/15/2024 6
