Design Span (L): 19.75 ft.
Clear Span: 19.50 ft.
Total Span: 20.00 ft.
Live Load: 220 plf
Dead Load: 110 plf
Selfweight: 172.8 lbs
Dist. Selfweight: 8.75 plf
Total Weight: 175.0 lbs
Beam Design 2024A44
2/8/2024 1
Beam Design 2024A44
2/8/2024 2
Volumetotal = N[A x (L + lb)] = 2 x [16.88 x (237.00 + 3)] x (12 in./ft.)3 = 4.69 ft3
Volumespan = N[A x L] = 2 x [16.88 x 237.00] x (12 in./ft.)3 = 4.63 ft3
Total Weight (WT) = ρw x Volumetotal = 37.33 x 4.69 = 175.0 lbs
Self Weight (WS) = ρw x Volumespan = 37.33 x 4.63 = 172.8 lbs
220 plf
110 plf
ws = 8.75 plf
19.75 ft.
19.50 ft.
3387.49 lbs
3387.49 lbs
Beam Design 2024A44
2/8/2024 3
fb = = 3132.1 psi
 fb = 3132.1 psi > Fbx' = 862.5 psi  (CSI = 3.63)   ➜  NG
Beam Design 2024A44
2/8/2024 4
fv* = = 134.56 psi
 fv* = 134.56 psi < Fvx' = 201.25 psi  (CSI = 0.67)   ➜  OK
fv = = 148.67 psi
 fv = 148.67 psi < Fvx' = 201.25 psi  (CSI = 0.74)   ➜  OK
Beam Design 2024A44
2/8/2024 5
ΔLL = = 1.51 in.
(L/d)LL = 237.00 / 1.51 = 157
 ΔLL = 1.51 in = L/157 > L/360   ➜  NG
ΔTL = = 2.33 in.
(L/d)TL = 237.00 / 2.33 = 102
 ΔTL = 2.33 in = L/102 > L/240   ➜  NG
fc⊥ = = 376.4 psi
 fc⊥ = 376.4 psi < Fc⊥x' = 565.00 psi  (CSI = 0.67)   ➜  OK
Beam Design 2024A44
2/8/2024 6
