Size: 4 x 12
Design Span (L): 8.00 ft.
Clear Span: 7.75 ft.
Total Span: 8.25 ft.
Live Load: 300 plf
Dead Load: 100 plf
Selfweight: 74.8 lbs
Dist. Selfweight: 9.35 plf
Total Weight: 77.2 lbs
Defl. Limits: 720|480
CL Beam Stability Factor 0.984 - - - - -
CF Size Factor 1.1 1 - 1 - -
Beam Design 2024A43
2/6/2024 1
Beam Design 2024A43
2/6/2024 2
Volumetotal = N[A x (L + lb)] = 1 x [39.38 x (96.00 + 3)] x (12 in./ft.)3 = 2.26 ft3
Volumespan = N[A x L] = 1 x [39.38 x 96.00] x (12 in./ft.)3 = 2.19 ft3
Total Weight (WT) = ρw x Volumetotal = 34.20 x 2.26 = 77.2 lbs
Self Weight (WS) = ρw x Volumespan = 34.20 x 2.19 = 74.8 lbs
300 plf
ws = 9.35 plf
7.75 ft.
8.25 ft.
1688.58 lbs
1688.58 lbs
Beam Design 2024A43
2/6/2024 3
lu = Unbraced Length = 8 ft.
lu/d = = 8.53
le = 1.63lu + 3d = 1.63(96.0) + 3(11.25) = 190.23 in. = 15.85 ft.  (NDS Table 3.3.3)
Rb = = 13.22
 Rb = 13.22 < 50   ➜  OK
Beam Design 2024A43
2/6/2024 4
FbE = = 3983.95 psi
Fbx* = Fbx(CD)(CM)(Ct)(CF)(Ci)(Cr) = (900)(1.00)(1)(1)(1.1)(1)(1) = 990.00 psi
CL =   = 0.984
Fbx' = (900)(1.00)(1)(1)(0.984)(1.1)(1)(1) = 974.2 psi
fb = = 532.3 psi
 fb = 532.3 psi < Fbx' = 974.2 psi  (CSI = 0.55)   ➜  OK
fv* = = 47.76 psi
 fv* = 47.76 psi < Fvx' = 180.00 psi  (CSI = 0.27)   ➜  OK
fv = = 62.38 psi
 fv = 62.38 psi < Fvx' = 180.00 psi  (CSI = 0.35)   ➜  OK
Beam Design 2024A43
2/6/2024 5
LL Allowable: L/720
TL Allowable: L/480
ΔLL = = 0.04 in.
(L/d)LL = 96.00 / 0.04 = 2307
 ΔLL = 0.04 in = L/2307 < L/720   ➜  OK
ΔTL = = 0.06 in.
(L/d)TL = 96.00 / 0.06 = 1691
 ΔTL = 0.06 in = L/1691 < L/480   ➜  OK
fc⊥ = = 160.8 psi
 fc⊥ = 160.8 psi < Fc⊥x' = 625.00 psi  (CSI = 0.26)   ➜  OK
Beam Design 2024A43
2/6/2024 6
