Beam Design - ROOF BEAMS
Size: 4 x 6
Design Span (L): 11.83 ft.
Clear Span: 11.67 ft.
Bearing (lb): 2 in.
Live Load: 60 plf
Dead Load: 10 plf
Selfweight: 54.1 lbs
Dist. Selfweight: 4.57 plf
Total Weight: 54.9 lbs
Beam Design MICHAEL LEWALLEN 319 NE CEDAR ST 2407
10/15/2024 1
10/15/2024 2
Volumetotal = N[A x (L + lb)] = 1 x [19.25 x (142.00 + 2)] x (12 in./ft.)3 = 1.60 ft3
Volumespan = N[A x L] = 1 x [19.25 x 142.00] x (12 in./ft.)3 = 1.58 ft3
Total Weight (WT) = ρw x Volumetotal = 34.20 x 1.60 = 54.9 lbs
Self Weight (WS) = ρw x Volumespan = 34.20 x 1.58 = 54.1 lbs
60 plf
10 plf
ws = 4.57 plf
11.83 ft.
11.67 ft.
447.42 lbs
447.42 lbs
10/15/2024 3
fb = = 887.6 psi
 fb = 887.6 psi < Fbx' = 1345.5 psi  (CSI = 0.66)   ➜  OK
10/15/2024 4
fv* = = 31.72 psi
 fv* = 31.72 psi < Fvx' = 207.00 psi  (CSI = 0.15)   ➜  OK
fv = = 34.38 psi
 fv = 34.38 psi < Fvx' = 207.00 psi  (CSI = 0.17)   ➜  OK
10/15/2024 5
ΔLL = = 0.34 in.
(L/d)LL = 142.00 / 0.34 = 417
 ΔLL = 0.34 in = L/417 < L/360   ➜  OK
ΔTL = = 0.42 in.
(L/d)TL = 142.00 / 0.42 = 335
 ΔTL = 0.42 in = L/335 < L/240   ➜  OK
Ab = b x lb = 3.5 x 2 = 7.00 in2
fc⊥ = = 63.9 psi
 fc⊥ = 63.9 psi < Fc⊥x' = 625.00 psi  (CSI = 0.10)   ➜  OK
10/15/2024 6
