Grade: SP DSS
Design Span (L): 5.25 ft.
Clear Span: 5.00 ft.
Total Span: 5.50 ft.
Live Load: 1800 lbs
Dead Load: 75 lbs
Selfweight: 29.6 lbs
Dist. Selfweight: 5.64 plf
Total Weight: 31.0 lbs
Beam Design 2024A417
10/3/2024 1
SP DSS 2200 1550 175 660 1850 1900000 690000 0.55
10/3/2024 2
Volumetotal = N[A x (L + lb)] = 2 x [10.88 x (63.00 + 3)] x (12 in./ft.)3 = 0.83 ft3
Volumespan = N[A x L] = 2 x [10.88 x 63.00] x (12 in./ft.)3 = 0.79 ft3
Total Weight (WT) = ρw x Volumetotal = 37.33 x 0.83 = 31.0 lbs
Self Weight (WS) = ρw x Volumespan = 37.33 x 0.79 = 29.6 lbs
1800 lbs
75 lbs
ws = 5.64 plf
5.25 ft.
5.00 ft.
5.50 ft.
953.01 lbs
953.01 lbs
10/3/2024 3
Fbx' = (2200)(1.15)(1)(1)(1)(1)(1)(1) = 2530.0 psi
fb = = 1132.5 psi
 fb = 1132.5 psi < Fbx' = 2530.0 psi  (CSI = 0.45)   ➜  OK
10/3/2024 4
fv* = = 65.44 psi
 fv* = 65.44 psi < Fvx' = 201.25 psi  (CSI = 0.33)   ➜  OK
fv = = 65.68 psi
 fv = 65.68 psi < Fvx' = 201.25 psi  (CSI = 0.33)   ➜  OK
10/3/2024 5
ΔLL =   =   = 0.05 in.
(L/d)LL = 63.00 / 0.05 = 1216
 ΔLL = 0.05 in = L/1216 < L/360   ➜  OK
ΔTL =   =   = 0.05 in.
(L/d)TL = 63.00 / 0.05 = 1156
 ΔTL = 0.05 in = L/1156 < L/240   ➜  OK
fc⊥ = = 105.9 psi
 fc⊥ = 105.9 psi < Fc⊥x' = 660.00 psi  (CSI = 0.16)   ➜  OK
10/3/2024 6
