Beam Design - Beam Calculation
Size: 3.5 x 9
Design Span (L): 18.21 ft.
Clear Span: 18.08 ft.
Total Span: 18.33 ft.
Bearing (lb): 1.5 in.
Live Load: 107 plf
Dead Load: 54 plf
Selfweight: 134.5 lbs
Dist. Selfweight: 7.39 plf
Total Weight: 135.4 lbs
Beam Design 003
9/30/2024 1
d = 9.000 in.
Beam Design 003
9/30/2024 2
Volumetotal = N[A x (L + lb)] = 1 x [31.50 x (218.50 + 1.5)] x (12 in./ft.)3 = 4.01 ft3
Volumespan = N[A x L] = 1 x [31.50 x 218.50] x (12 in./ft.)3 = 3.98 ft3
Total Weight (WT) = ρw x Volumetotal = 33.76 x 4.01 = 135.4 lbs
Self Weight (WS) = ρw x Volumespan = 33.76 x 3.98 = 134.5 lbs
107 plf
54 plf
  ws = 7.39 plf
18.21 ft.
18.08 ft.
18.33 ft.
1543.50 lbs
1543.50 lbs
Beam Design 003
9/30/2024 3
Fbx' = (2400)(1.00)(1)(0.8)(1.0) = 1920.0 psi
fb = = 1772.2 psi
 fb = 1772.2 psi < Fbx' = 1920.0 psi  (CSI = 0.92)   ➜  OK
Beam Design 003
9/30/2024 4
Fvx' = (265)(1.00)(1)(0.8) = 212.00 psi
fv* = = 66.99 psi
 fv* = 66.99 psi < Fvx' = 212.00 psi  (CSI = 0.32)   ➜  OK
fv = = 73.00 psi
 fv = 73.00 psi < Fvx' = 212.00 psi  (CSI = 0.34)   ➜  OK
Beam Design 003
9/30/2024 5
ΔLL = = 0.77 in.
(L/d)LL = 218.50 / 0.77 = 284
 ΔLL = 0.77 in = L/284 < L/240   ➜  OK
ΔTL = = 1.21 in.
(L/d)TL = 218.50 / 1.21 = 181
 ΔTL = 1.21 in = L/181 < L/180   ➜  OK
Ab = b x lb = 3.5 x 1.5 = 5.25 in2
fc⊥ = = 294.0 psi
 fc⊥ = 294.0 psi < Fc⊥x' = 520.00 psi  (CSI = 0.57)   ➜  OK
Beam Design 003
9/30/2024 6
