Beam Design - samplae beam 2
Grade: DF No.1
Design Span (L): 19.75 ft.
Clear Span: 19.50 ft.
Total Span: 20.00 ft.
Live Load: 320 plf
Dead Load: 80 plf
Selfweight: 158.3 lbs
Dist. Selfweight: 8.02 plf
Total Weight: 160.3 lbs
Lateral Support: 10' o/c
CL Beam Stability Factor 0.971 - - - - -
Beam Design 999999
9/25/2024 1
Beam Design 999999
9/25/2024 2
Volumetotal = N[A x (L + lb)] = 2 x [16.88 x (237.00 + 3)] x (12 in./ft.)3 = 4.69 ft3
Volumespan = N[A x L] = 2 x [16.88 x 237.00] x (12 in./ft.)3 = 4.63 ft3
Total Weight (WT) = ρw x Volumetotal = 34.20 x 4.69 = 160.3 lbs
Self Weight (WS) = ρw x Volumespan = 34.20 x 4.63 = 158.3 lbs
320 plf
80 plf
ws = 8.02 plf
19.75 ft.
19.50 ft.
4080.16 lbs
4080.16 lbs
Beam Design 999999
9/25/2024 3
lu = Unbraced Length = 10 ft.
lu/d = = 10.67
le = 1.63lu + 3d = 1.63(120.0) + 3(11.25) = 229.35 in. = 19.11 ft.  (NDS Table 3.3.3)
Rb = = 16.93
 Rb = 16.93 < 50   ➜  OK
Beam Design 999999
9/25/2024 4
Eminy' = Eminy(CM)(Ct)(Ci) = 620000(1)(1)(1) = 620000 psi
FbE = = 2595.16 psi
Fbx* = Fbx(CD)(CM)(Ct)(CF)(Ci)(Cr) = (1000)(1.00)(1)(1)(1)(1)(1) = 1000.00 psi
CL =   = 0.971
Fbx' = (1000)(1.00)(1)(1)(0.971)(1)(1)(1) = 971.0 psi
fb = = 3772.5 psi
 fb = 3772.5 psi > Fbx' = 971.0 psi  (CSI = 3.89)   ➜  NG
fv* = = 162.07 psi
 fv* = 162.07 psi < Fvx' = 180.00 psi  (CSI = 0.90)   ➜  OK
fv = = 179.07 psi
 fv = 179.07 psi < Fvx' = 180.00 psi  (CSI = 0.99)   ➜  OK
Beam Design 999999
9/25/2024 5
ΔLL = = 1.81 in.
(L/d)LL = 237.00 / 1.81 = 131
 ΔLL = 1.81 in = L/131 > L/360   ➜  NG
ΔTL = = 2.31 in.
(L/d)TL = 237.00 / 2.31 = 103
 ΔTL = 2.31 in = L/103 > L/240   ➜  NG
fc⊥ = = 453.4 psi
 fc⊥ = 453.4 psi < Fc⊥x' = 625.00 psi  (CSI = 0.73)   ➜  OK
Beam Design 999999
9/25/2024 6
