Size: 5.5 x 13.5
Design Span (L): 19.75 ft.
Clear Span: 19.50 ft.
Total Span: 20.00 ft.
Live Load: 40 plf
Dead Load: 25 plf
Selfweight: 343.8 lbs
Dist. Selfweight: 17.41 plf
Total Weight: 348.2 lbs
CV Volume Factor 0.987b - - - - -
Beam Design 2024A41
2/2/2024 1
d = 13.500 in.
Beam Design 2024A41
2/2/2024 2
Volumetotal = N[A x (L + lb)] = 1 x [74.25 x (237.00 + 3)] x (12 in./ft.)3 = 10.31 ft3
Volumespan = N[A x L] = 1 x [74.25 x 237.00] x (12 in./ft.)3 = 10.18 ft3
Total Weight (WT) = ρw x Volumetotal = 33.76 x 10.31 = 348.2 lbs
Self Weight (WS) = ρw x Volumespan = 33.76 x 10.18 = 343.8 lbs
40 plf
25 plf
  ws = 17.41 plf
19.75 ft.
19.50 ft.
824.08 lbs
824.08 lbs
Beam Design 2024A41
2/2/2024 3
CV = = 0.987
CV = 0.987 < CL = 1
Fbx' = (2400)(1.15)(1)(1)(0.987) = 2725.2 psi
fb = = 288.6 psi
 fb = 288.6 psi < Fbx' = 2725.2 psi  (CSI = 0.11)   ➜  OK
Beam Design 2024A41
2/2/2024 4
fv* = = 14.57 psi
 fv* = 14.57 psi < Fvx' = 304.75 psi  (CSI = 0.05)   ➜  OK
fv = = 16.44 psi
 fv = 16.44 psi < Fvx' = 304.75 psi  (CSI = 0.05)   ➜  OK
Beam Design 2024A41
2/2/2024 5
ΔLL = = 0.07 in.
(L/d)LL = 237.00 / 0.07 = 3513
 ΔLL = 0.07 in = L/3513 < L/360   ➜  OK
ΔTL = = 0.14 in.
(L/d)TL = 237.00 / 0.14 = 1705
 ΔTL = 0.14 in = L/1705 < L/240   ➜  OK
fc⊥ = = 49.9 psi
 fc⊥ = 49.9 psi < Fc⊥x' = 650.00 psi  (CSI = 0.08)   ➜  OK
Beam Design 2024A41
2/2/2024 6
