Beam Design - Tractor Shed
Size: 5.5 x 9
Design Span (L): 19.54 ft.
Clear Span: 19.08 ft.
Total Span: 20.00 ft.
Bearing (lb): 5.5 in.
Selfweight: 453.6 lbs
Dist. Selfweight: 23.21 plf
Total Weight: 464.2 lbs
Beam Design D W 8819 1
9/25/2024 1
d = 9.000 in.
9/25/2024 2
Volumetotal = N[A x (L + lb)] = 2 x [49.50 x (234.50 + 5.5)] x (12 in./ft.)3 = 13.75 ft3
Volumespan = N[A x L] = 2 x [49.50 x 234.50] x (12 in./ft.)3 = 13.44 ft3
Total Weight (WT) = ρw x Volumetotal = 33.76 x 13.75 = 464.2 lbs
Self Weight (WS) = ρw x Volumespan = 33.76 x 13.44 = 453.6 lbs
  ws = 23.21 plf
19.54 ft.
19.08 ft.
1982.14 lbs
1982.14 lbs
9/25/2024 3
fb = = 764.6 psi
 fb = 764.6 psi < Fbx' = 2760.0 psi  (CSI = 0.28)   ➜  OK
9/25/2024 4
fv* = = 27.09 psi
 fv* = 27.09 psi < Fvx' = 304.75 psi  (CSI = 0.09)   ➜  OK
fv = = 29.34 psi
 fv = 29.34 psi < Fvx' = 304.75 psi  (CSI = 0.10)   ➜  OK
9/25/2024 5
ΔLL = = 0.27 in.
(L/d)LL = 234.50 / 0.27 = 860
 ΔLL = 0.27 in = L/860 < L/360   ➜  OK
ΔTL = = 0.54 in.
(L/d)TL = 234.50 / 0.54 = 434
 ΔTL = 0.54 in = L/434 < L/240   ➜  OK
fc⊥ = = 32.8 psi
 fc⊥ = 32.8 psi < Fc⊥x' = 650.00 psi  (CSI = 0.05)   ➜  OK
9/25/2024 6
